Dynolicious
Old Nov 13, 2008 | 02:08 AM
HB_SS/TC's Avatar
Dynolicious
I just got the app and did a quick little test. Only took it to second gear
If anybody else has this app please post your results!
Old Nov 13, 2008 | 02:11 AM
Chad92's Avatar
I've seen this app. How does it work?
Wolf117's Avatar
did you actually mount it? i used to have it and it wasnt really accurate unless its mounted or something where it cant move at all really.
Old Nov 13, 2008 | 02:14 AM
HB_SS/TC's Avatar
I didn't mount it just put it in the little area under e-brake handle. I have the silicone cover so maybe it prevented it from slipping.
Old Nov 13, 2008 | 02:16 AM
SI FTL's Avatar
ive got this app. Its close for using gforces and gps. It has to be mounted and still or it will give wack readings such as my cobalt once had 837hp and 14.6 in 1/4 mile. Ure arm can usually net over 2000hp haha.
Old Nov 13, 2008 | 02:17 AM
car_guy_09's Avatar
How much does this cost?
Old Nov 13, 2008 | 02:19 AM
HB_SS/TC's Avatar
$12.99
Old Nov 13, 2008 | 02:21 AM
Wolf117's Avatar
hahaha i used to just sit in class and see how much i can get when i was bored
car_guy_09's Avatar
me and my buddy might have to buy this and play around with it
Old Nov 13, 2008 | 02:26 AM
SI FTL's Avatar
check out rev lite. Should be a really interesting app. Its obd2 communications hardware so itll act like an interceptor as well as hp readings quartermile times etc. Pricing for the full version should be released this month. I bet it will be costly seeing it uses wireless obd hardware.
Old Nov 13, 2008 | 02:29 AM
raptors_67's Avatar
I've used it quite a few times. As long as it is positioned so it can't slip or move it's pretty accurate. My best HP number was 262 which is pretty close to correct.
Old Nov 13, 2008 | 02:35 AM
Blown 4-banger's Avatar
Can someone link me to where I can get this app???
Old Nov 13, 2008 | 02:48 AM
HB_SS/TC's Avatar
If you have an iPhone/iTouch it's in the app store.
Old Nov 13, 2008 | 01:02 PM
rms7design's Avatar
mine reads
0-50 5.04 sec
0-60 6.06 sec
60' 2.74
330' 6.60
Old Nov 13, 2008 | 01:10 PM
SKCobalt's Avatar
That looks really interesting. I wonder when the full version with the OBDII connection will be available. I really like the idea of being able to connect to it via wireless instead of having to plug your phone into the car all the time!
Old Nov 13, 2008 | 02:18 PM
EvilleCobalt's Avatar
I've got this application. It said I had 165hp at the crank before my tune. On a mustang dyno before my catback and tune I put down 140hp to the wheels so it seems to be pretty accurate. I'm really waiting for Rev to come out. Using your phone as a scan tool sounds sweet.
Cobalt_Daddy
Canadian North East
56
Mar 28, 2010 05:22 PM
06SS ALL DAY
Nov 17, 2008 10:30 PM
