Engine break in
Old Aug 18, 2017 | 09:51 AM
jdbaugh1's Avatar
Engine break in
How many miles do you guys think I need to run conventional oil for break in before switching back to synthetic?
Old Aug 18, 2017 | 11:42 AM
cw383's Avatar
I ran the Comp cams break in oil for 200 miles, dumped that, changed filter and used regular oil to 3000 total miles, then added in Mobil 1. I use the cars oil life calculator. When I pulled my old LNF apart at 130k the crank, bores and bearings were perfect
Old Aug 18, 2017 | 11:46 AM
exninja's Avatar
This ^ is good. ZZP recommends comp cams oil for 200 miles, but they don't specify anything after that.
Old Aug 18, 2017 | 11:51 AM
jdbaugh1's Avatar
I've been running Lucas break in oil additive (basically adding lots of zinc) for about 600 miles so far. I did first oil change at 200 miles and am about to hit 500 on second with additive. After this I probably don't need the zinc anymore? I will probably still used it on next change anyway. Not worried about the CAT. How many miles do you guys think I should put on this second oil change with zinc? I originally planned to change it at 500 but that might be overkill. Think if I ran conventional for about 1,500 miles I would be good to switch back to synthetic?
Old Aug 18, 2017 | 11:56 AM
exninja's Avatar
At this point yeah I'd do conventional for a few miles then go to normal intervals with synthetic. I'd pretty much only do the conventional to get all of the additive cleaned up, so I doubt you'd need or want all 1500 miles with it.
