Engine CODES!!!!
my car is throwing these three codes...
P0098 - intake air temperatureS2 Ckt High (to much electricity going into that circuit) P0128 - Coolant thermostat P0480 - Cooling Fan 1 Ctrl CKT malfunction these are the codes but the shop wants like 90 bucks to diagnose the issue. can you guys give me some advice on how to fix these issues? my check engine light came on after flooring speed testing my car...i got up to like 140 but that did not last to long...does that have anything to do with any of this? |
First thing to check is all your fuses under the hood.
(Post 7632149)
would definitely cause you IAT's to be through the roof, probably got some pretty wicked KR
Originally Posted by calo247
(Post 7632159)
Originally Posted by Isaac Lewis
(Post 7632161)
what do you mean by KR?
there was no knock what so ever. and no need to insult thank you.
i am not insulting you, that is what its called when you take away timing.....
and you wont hear the knock because of the KR, your engine does it before you hear it usually. i can assure you that if you did a 140mph pull with no coolant in the heat exchanger you would be getting KR. this is probably where the P0098 code is coming from as well, intake charge is WAAAAY too hot |
oh ok. i see. so KR is like a fail safe? haha. not trying to be all sensitive here either.
yes, but if you are getting KR its a sign of other problems, its still hard on the engine because if you getting KR it means you had or are having knock.
make sure that the heat exchanger pump is working as well as the engine fan and everything has the right amount of coolant in it. |
ok. so what do you think about the other two codes then? i just filled up my supercharger coolant. an air bubble in the system let all of it bleed out most likely so thats why it was empty. but as far as the thermostat code and the fan code, what do you think about those? and this is the ONLY time this has ever happened. i have put maybe 60 miles on the car since the engine light came on with 0 issues. am i good?
Well the P0098 code could be a wiring issue or a bad sensor, not sure which sensor on the lsj is IAT2
P0128 is for Engine Coolant Temperature (ECT) Below Thermostat Regulating, probably need a new t-stat, what is your coolant temp at after driving around for awhile? P0480 is likely a wiring or connector issue with the radiator fans (LSJs have 2), to test the fans turn the AC on and let it go for a few mins then pop the hood and see if both fans are on. I also strongly recommend you get everything worked out on your car (including checking tires for age) prior to opening the car up above 110. I'm sure the ECU was pulling timing like crazy if it didn't have fluid in the heat exchanger (unless it has a crap tune on it then you'll be needing an engine soon I'm sure) |
i believe the IAT2 is part of the MAP sensor on the top of the manifold
(Post 7632181)
damn. my coolant was reading at like 178 or something....pretty normal. it was like 20 degrees outside when this happened. even having this happen once is so bad, my engine could blowt? damn....and all three codes came on at once...and my tires are just fine. the tread is getting down there but i have Continental extreme contacts on my car...so no problems there. grip was just fine. and the heat exchanger cools my supercharger not the engine correct?
If you have a junk tune the engine can be in danger, stock tune will be fine. If it takes to long to heat up it can cause that code
well i think my tune is pretty good. but i have a stage 3 kit on my car....there is one issue though. i do have some very slight idle surge. my tuner says the 60lb injectors can be hard to tune and he was gonna have to fool around with them to get rid of the idle surge in them....or something like that....but my car has plenty of power. the guy that tuned my car has done all types of vehicles. from what i know that is. but i dont think its a shitty tune though. thank god i didnt go that speed the whole way to work. this was like a 2/3 to a 3/4 mile stretch i did this. then i just drove to work like normal person would....
Do you have an cooling mods to go with the rest of the parts?
Definitely get the heat exchanger fluid figured out, it went somewhere. |
yeah that is weird that is just disappeared....my brother is an experienced mechanic who replaced my clutch and he said an air bubble in the system let it all bleed out. im not a mechanic and i cant work on cars so i go on his input alone....and the best cooling mod i have is probably my mishimoto radiator.
(Post 7632189)
(Post 7632189)
I was meaning like option b, dual pass, etc assuming you're running a 2.7 or 2.8" pulley you need something to help with the heat generated. |
(Post 7632166)
ill have to double check but i think its the oversized radiator? i beleive it hold more coolant than the stock one. and no i do not have option b or a dual pass or anything....i should but neither were on the car when i bought it and i first had to buy a new clutch, down pipe, radiator...stuff like that. so now i can finally get around to dong better cooling mods.
(Post 7632203)
I'm sorry, this just made me laugh out loud.
(Post 7632208)
i would laugh too. i seriously thought he called me a retard. hahaha.
Once you get some experience under your belt and start working on the car a lot, you can pass down the things you learned while doing it to the next noob that comes along. That's how it's supposed to work. |
