Engine Control Module (ECM) loose
Old May 10, 2007 | 01:08 AM
Forseti's Avatar
Is everyone's ECM (Silver box in front of positive battery terminal box) loose to the touch? Mine is a friction fit, and moves a lot...I am thinking I may have to add a screw to keep it in place....
If you go into the engine compartment on an SS/SC, does yours move a certain amont?
Old May 10, 2007 | 01:12 AM
Dead Zen's Avatar
mine does thought that was kinda odd but i guess not
Old May 10, 2007 | 01:14 AM
Super_SS's Avatar
so does mine....mine only moves up..no left and right
Old May 10, 2007 | 01:28 AM
Forseti's Avatar
It can't be good for that thing to be shaken around while driving all the time....
Old May 10, 2007 | 07:57 AM
OzzyruleZ's Avatar
mine is loose i thought the same thing and i zip tied it. last time i took it to the dealer the ******** cut my zip ties and told me "its supposed to be like that" so oh well they can replace it when it dies.
Old May 10, 2007 | 10:32 AM
Halfcent's Avatar
I'm old school
They are all that way. The box they sit in is the same for all the cars, but each computer is a different shape. If you have an automatic, there are two computers, in case you ever wondered why there are two slots there. It's perfectly normal. I've never heard of a computer failing due to shock.
Old May 12, 2007 | 12:54 AM
Forseti's Avatar
Shock would not register...generally, an ECM just...fails...and is replaced, not put on a bench at the dealership and repaired. If an ECM fails due to a broken or fatigued out solder connection from being constantly shaken, that can't be determined unless a rather comprehensive failure analysis procedure is done on the unit. And that does not happen to every unit....
Old May 12, 2007 | 12:59 AM
06' SS2SS's Avatar
Mine started to rub on my CAI. I thought it made a couple of holes in it, but I found it before that happened. I filed down the two fins that were causing the problem just enough so it won't put holes in the CAI.
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
jmelton327
Sep 26, 2015 10:04 PM
reybalt
Sep 25, 2015 08:28 PM
