fog on initial defrost
Old Nov 27, 2009 | 09:32 PM
mikalpe's Avatar
I have a 2006 SS 2.4 na. Often, when I turn the defroster on, it will fog up the windshield. And there is a musty smell. I was wondering if anybody had this problem. And does anyone know where the drain(s) for the HVAC plenum is?
Old Nov 27, 2009 | 09:37 PM
Cobalt_Daddy's Avatar
had this problem with other GM vehicles.... mold does occasionaly grow in your ducts. You can buy a spray that you spray into your cowl while the blower motor is on to help deodorize and kill any contaminants. As for the fogging... do you have the air on recirc? that often causes windows to fog faster as the moist air inside the car is getting reused. If not then i'm not sure... maybe moisture is getting into your heating ducts somewhere.
Old Nov 27, 2009 | 09:43 PM
SeVeReDiStOrTiOn's Avatar
Evap drain is behind the engine on the pass side firewall. Buy some evaporator anti-fungal cleaner (don't get the cheap stuff) and spray it up the drain...NAPA carries it. Fogging up when the defroster is first on is normal...the air is still cold and the a/c hasn't had time to dry the air out yet.
Old Nov 27, 2009 | 09:44 PM
mikalpe's Avatar
No, I don't have the recirc on. I had a problem with my Saab 9000 similar to this until I cleaned out the drain for the plenum where the heater core and cooling coil sat. There was an actual drain with a flapper type valve on it. I don't see anything obvious on the Cobalt, but then again, I don't have a lift and cannot easily see...
Old Nov 27, 2009 | 09:46 PM
Originally Posted by mikalpe
No, I don't have the recirc on. I had a problem with my Saab 9000 similar to this until I cleaned out the drain for the plenum where the heater core and cooling coil sat. I don't see anything obvious, but then again, I don't have a lift and cannot easily see...
Mold smell is from your evaporator...defrost turns the a/c compressor on.
Old Nov 27, 2009 | 09:47 PM
mikalpe's Avatar
Thanks, now I'll know where to look...
Old Nov 28, 2009 | 01:54 AM
rukkee's Avatar
You might want to check the cabin air filter if your getting some bad smell's . Ive seen some nasty **** on those .
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
turbostang
Nov 24, 2004 08:45 AM
