fuse box delema
fuse box delema
so i cant find any info i need anywere on this forum...all the how to's do not help on this matter....everyone used a add a fuse to connect there meth pump to a fuse in the fuse box.....but no where in tucson has this for anything more than 10amps...the pump needs atleast 15 amps..so that will not work..how else can i run power to my pump............
are you talking about how to add a fuze into the wiring to protect the pump...cus thats not what im askin....im not sure how to physically connect my pump to a power source...like what type of connection...?
they make a fuze with a wire that runs off of it but those are all only for 10 amps...
you can use the one your talkin bout with a bigger fuse. im usin one now with a 20 amp fuse in it now and its held the load so far.
the only reason its only rated for a 10 amp is the size of the wire that comes outta it. it can handle more thou.
Last edited by yellowltcoupe22; Jul 12, 2008 at 10:14 PM. Reason: Automerged Doublepost
ohh so the one that sais 10 amp is still ok????it looks like this right.......
http://www.autoelectricsupplies.co.u...ads/100215.gif
so just take this and and plug it into one of the fuses and crymp the wire with the one off the pump?
which fuse is everyone using?
