Gas Mileage with stage 2 supercharger upgrade
thanks alot u guys man i was worried because im on the verge of ordering mine but i was worring with the 19 mpg im gettin now i didnt know if upgrading should be in the picture
i usually shift at 3000 i bought it used with 14000 miles on it..but im just going off what my info thing says i havent really did the math myself
also am i the only idoit that has a ss/sc with no sunroof?
Well i see it like this my opinion ok the stage 2 has bigger injectors ok but if you dont drive your car hard and faster then you did when you were stock then you will be having about the same amount MPG the bigger injectors allow more flow of fuel when the gas pedal is pressed so if you dont drive it like animal with the stage 2 then you should get about the same MPG as stock
Have them check the fuel filter or the 02 sensors might be bad causing bad gas milage, check the air filter, tire pressure... anything! Might change gas stations and see if there is a difference!
haha not changing gas stations u civilians pay to much!! but ima check that stuff out got her on monday and have a 89 caprice thats been giving me hell so i havent been able to get under my black beauty but i will..
