headlight aiming
headlight aiming
The headlights on the 2005 seem aimed too low. How can I adjust them? There is what looks like one adjuster over the bulb on the back of the housing. It has a allen bolt pointing upright which rotates a threaded bolt which goes into the housing. It's not directly over the headlight and there's only one. It's the only thing which looks like it could be an adjuster. Can anybody tell me if that's an adjuster and how can I adjust them up with only one adjuster? Thanks
https://www.cobaltss.net/forums/show...ign+headlights
i see your new, welcome.
the search option will work wonders for you in the future.
Originally Posted by skitzianist
there are bolts on it that you crank one way or the other to make them go up and down, left to right, make sure you turn the right ones or else the high beams might move
brickloaf
Sep 21, 2015 02:17 PM
