Headlight bulb change.
Old Mar 1, 2016 | 10:20 PM
soccerkid13's Avatar
Hey guys just running a quick question by you as far as headlights go.
As most of you know the stock head lights for the cobalt are 65/55. There is a good deal that i have been offered to get 100/80w halogen bulbs. As far as i know those will deform the harness i believe but i am not sure, either way i have heard its risky move to put those bulbs in on the stock setup. SO my question is is there a way to beef up the system so that it could with stand the bulbs. upgraded harness maybe? Im not sure, I'm lost as far as electrical stuff goes so I figured i would ask!
Thanks guys!
Old Mar 1, 2016 | 10:36 PM
turboecotec02's Avatar
Thanks guys!
Hid?
Old Mar 1, 2016 | 11:05 PM
Originally Posted by turboecotec02
Hid?
No just plug and play off modern performance I think
Old Mar 1, 2016 | 11:58 PM
cluelessk's Avatar
Deform? You mean melt?
Stick with what works. Insurance probably won't be too kind after you burn your car down.
Old Mar 2, 2016 | 12:13 AM
Sharkey's Avatar
yes there is a way, you can run relays. however the extra heat given off by a 100/80w bulb could melt the headlight housings.
Old Mar 2, 2016 | 10:17 AM
So if 100/80w will melt everything an suggestions on what a good bluish/white colored bulb would be without going Hid or having to do anything to modify the headlight?
Old Mar 2, 2016 | 11:30 AM
cluelessk's Avatar
Expensive bulbs. They usually only last me a year though.
Old Mar 3, 2016 | 01:12 PM
kcg795's Avatar
They won't be much brighter anyway. You'll basically be getting a diminishing return. As the light down the road increases, so will the foreground light. The extra foreground light will make it harder for you to see the extra light down the road. Some of those high wattage bulbs aren't aligned properly either, so the beam pattern may be off. I actually do have a box of 9007 high wattage bulbs. The stock 55/65 watt Philips bulbs actually work better. Also, don't listen to any bad advice about putting HIDs in your stock headlights either. Just do a retrofit with HID projectors and call it a day. You won't regret it.
Old Mar 3, 2016 | 05:27 PM
cluelessk's Avatar
LED head lights have come pretty far. I'm considering getting a pair.
Old Mar 3, 2016 | 11:10 PM
Fsanti87's Avatar
They have not come nearly far enough. Seriously pnp led is still worse than halogen when you consider the glare and lack of distance especially in reflectors
CobaltSS 16
Feb 18, 2016 07:56 AM
jdbaugh1
Feb 17, 2016 08:16 PM
Immer
Feb 12, 2016 11:37 AM
GreenStang
Feb 10, 2016 11:03 PM
jcalvin1126
Feb 7, 2016 08:50 AM
