Headlight bulbs are a B****
Anyone have any secerts on how to get the darn headlight assey out so I can change my blown out bulb.
The headlight unit wont come out past the fender and bumper corver enough to replace bulb. Am I missing something?? I took the 2 silver bolts out and it came loose but just wont pass the fender and bumper cover..Ahhhhhhh.:cussing::cussing: Thanks for any help. Ps.. I did do a search and all that came up was replacing fog light bulbs. |
You're going to want to push the inside corner (lower part near the grille) in first, then you should be able to wiggle the outside of the housing loose, and pull it out toward the side of the car. It's a bitch, but can be done.
just wiggle it till it comes out. you have to kinda angle the headlight to get it out.
did you pop the clips?
http://i164.photobucket.com/albums/u...heap/clips.jpg i found it easier because then you can full the front piece back, gives you more wiggle room. |
yup pop the clips... read your manual! It actually tells you how to do it pretty easily in there :lol:
I've replaced bulbs quite a few times (crappy cheap bulbs) and I've never popped the clips. My Hella bulbs are on the way!!
if ur just changing bulbs you dont need to take them out
grow balls and pull haha. thats what i did
yes you do need to take them out and here this should help as half of the how to is removing and reinstalling the headlights.
https://www.cobaltss.net/forums/deleted-threads-89/painting-your-headlights-detailed-w-pictures-64144/ |
Originally Posted by outtamymind
(Post 2052431)
https://www.cobaltss.net/forums/showthread.php?t=64144 |
then you've got really small hands. cuz i've done a fair amount and i can't get them out without taking out the headlamp assembly.
Originally Posted by CobaltCoupeCrazy
(Post 2052418)
i just changed mine to PIAA bulbs. The headlight assembly is a bitch to get out, but once you figure it out, it's easy.
Originally Posted by Mr_Slobalt
(Post 2052459)
you must touch the bulbs with your fingers if they keep going out
THANKS!!
Originally Posted by BlackSSNick
(Post 2052898)
Originally Posted by originaladrian
(Post 2052434)
??? you do not need to take them out to change a bulb i have changed them many times on my old stock ones without doing that. Its one twist and the bulb is out.
