Headlight removal is a B
After wrestling with them in the cold for an hour, I gave up. I got the drivers side out ok, but the bulb WOULD NOT come out of there. Out of every vehicle I've owned, this is by far the WORST to replace freaking headlight bulbs. Yes, I removed the bolts and clips and still could not get them out. I don't feel like cracking or scratching my paint.
Maybe I'll try another day. For now, it's just too cold outside and my Camaro is not leaving the garage on it's own power. The stock bulbs suck in these cars, so I bought Philips Crystal Vision Ultra's and I want to put them in.
i have gen 1 projectors. the aiming system sucks and the bulbs burnt out on me 3 times in less then a year. everytime i put in a new bulb i have to re-aim them, which means i have to take them out. i can remove both headlights now blind folded, hanging upside down, and using only my feet. those lights have been in and out sooooo many times. once you get to it, and take you time, it will become clock work.
also, after market, brighter lights, usually have a lower life span, so you will have to change them more often....get used to it
You dont even have to remove the headlights to change the bulb. Rotate that ring, pull out bulb, replace bulb, reinsert bulb, lock ring into place. Simple.
It's all there in the owners manual, btw.
Last edited by chris88z24; Feb 26, 2009 at 12:33 PM. Reason: Automerged Doublepost
I read the manual. It said to pull the housings. How did you fit your hand in there without removing them?
Thanks for the 2˘, C0balt2007.
Yeah, I was helping a friend put an intake in his SSTC the other day and we had a heck of a time getting it out, while not scratching the paint on the top of the bumper. I'm going to try some of the methods described here next time I take them out and see if it's any better.
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
