Headlight Seal
Headlight Seal
For those of you that have done retros or taken apart your headlights, what did you use to put a new seal on? Did you use the OEM stuff that's still on the housing? I was planning on using a new sealant, but I didn't know if I should just go to Home Cheapo and buy a caulk or something like that. Too many to choose from. Thanks in advanced.
Well one had the common condensation so I didn't know if I was going to have to replace it with a new sealer.. That was my concern with reusing the seal but I'll find out I guess lol
Agreed. Good silicone well the kind I use for roofing is 11.00, and well it is messy and gross looking if it squashes out.
That crap has been around as long as the dinosaurs. You want a permeant fix for a chimney or wall, roofing cement. This crap we have now sucks. The old wet dry stuff I have literally seen a fully standing water flat roof. Apply under water and it seal. This new stuff sucks. God I am old
https://www.cobaltss.net/forums/how-...ics%5D-282150/
You can see what I did in the above link...
As others have stated above, I would scrape out as much of the old OEM sealant as you can. Once you're done doing that, apply OCI Butyl Rubber Glue from The Retrofit Source
