Heated seats light not working
Old Nov 6, 2013 | 08:48 AM
CobaltSS 16's Avatar
My driver's side heated seat light is not working anymore. (the part with the little seat)
How do I go about fixing this? I thought it may have been a bulb and went to the dealer and they wanted to charge me a ton of money since they said it was a sensor? I havent taken out the dash yet, any input??
BTW the passenger side is fine.
Old Nov 6, 2013 | 08:58 AM
blueLNFftw's Avatar
its a light bulb
Old Nov 6, 2013 | 09:31 AM
oh yea? Ok sounds like an easy fix. thanks
Old Nov 6, 2013 | 09:45 AM
Squints's Avatar
You're going to need to solder in a surface mount led sounds easy until you do it
Old Nov 6, 2013 | 09:55 AM
blueLNFftw's Avatar
Squints beat me to it.
It would be easy but they are solder bulbs...
Old Nov 6, 2013 | 10:14 AM
yellowsupercharged06's Avatar
push the button, if your ass is hot its on, if not then push the button again and you should feel the heat
Old Nov 6, 2013 | 10:27 AM
Squints's Avatar
He said the light wasn't working not that the heated seats weren't working
Old Nov 6, 2013 | 10:43 AM
i know, the light is there to tell you if the seat is on/off, i was being a smart ass
Old Nov 6, 2013 | 10:46 AM
Squints's Avatar
Don't make press the button yellow?
Old Nov 6, 2013 | 10:53 AM
andrewcarr1993's Avatar
Isn't a new switch only about $25, just replace the switch yourself.
Old Nov 6, 2013 | 11:17 AM
05g5's Avatar
I wish the only problem i had was a light indicating if a heater seat was working or not... You cant tell if its on or off... Or?
Old Nov 6, 2013 | 11:58 AM
damn do you guys not read lol. the heated seats work, but the light is burnt. you can even see the i have the low setting on and that bar is lit up. I'll take out the dash and check behind it, not really a big priority at this point.
Old Nov 6, 2013 | 12:10 PM
or dont fix it and use your sense of touch
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
brandon04
Oct 21, 2015 07:04 AM
Cptnslo
Sep 24, 2015 09:32 AM
