Help!!
Old Aug 30, 2007 | 11:41 AM
SC cobaltss15's Avatar
Help!!
Does aanyone know how to get to the back of the radio without breaking anything.... Also where should i put my cb..It needs to be hitten!! i dont want women being like whats that ahhaha
Old Aug 30, 2007 | 11:44 AM
trent_ky's Avatar
Take of the silver trim (just pull it hard but be careful not to break the clips. Take the one under the passenger airbag off first then the one with the buttons by the steering wheel and then the one surrounding the radio. You will then see 4 bolts that hold the head unit in loosen them and she'll come right out
Old Aug 30, 2007 | 11:57 AM
DrPuttsSS/SC's Avatar
https://www.cobaltss.net/forums/show...removing+radio
^ Link will show you how to remove radio.
As far as hiding CB, depends on what you have, obviously.
If yours was meant to be hidden (like all controls and readout on mic) I guess you wouldn't have asked the question.
If it's big, maybe inside glove compartment?
If it's small enough, pull out cupholders and see if you can put it down there somewhere. Or put it below radio, make plastic removable/flip-up cover?
Just trying to help.
Old Aug 30, 2007 | 11:58 AM
lucky_lellow06's Avatar
Helps to have a knife to get the little pop rivets (or whatever the heck they're called) to let go of the trim. It's a royal PITA, but it's definitely doable.
Old Aug 30, 2007 | 02:51 PM
okay true... i have too i think i am just gonna put the small one in which is the cobra 19 40 channel son.. and doo have mic
