Help with car
Help with car
Hey everyone so i just went to turn on my car today and hadnt ran it for 3 days.
Its throwin codes P2176 Minimum throttle not learned and 2101 and 1516 Tac Performance. I dont know whats goingf on. Can someone help?
Bump need help!
help
Bump need help!
help
The codes are telling you the tb butterfly didnt close all the way when you tuned the key on.
• Minimum pedal value--At key-up the powertrain control module (PCM) updates the learned minimum pedal value.
• Minimum throttle position (TP) values--At key-up the PCM updates the learned minimum TP value. In order to learn the minimum TP value, the throttle blade is moved to the closed position.
Throttle butterfly was probably stuck from sitting for 3 days ,if car doesnt go in to reduced power mode and runs fine then I dont think its a problem and the codes will go away.
