Help Major Confusion!!!
Old Jan 10, 2012 | 06:52 PM
cobalt20's Avatar
Angry Help Major Confusion!!!
Ok so i bought a 2.5 Catted ZZP Downpipe and the CEL came on a day later I drove with it on for a month. And went to a Muffler Shop they told me I have to install my stock downpipe because all aftermarket downpipes throw codes.....Im really confused can someone help me Please.!! The reason why i bought this ZZP downpipe was because i get Flex pipe leaks every 3 months or so.
Old Jan 10, 2012 | 06:57 PM
Elite v1's Avatar
Take the car to autozone and see what the code is. That would be the only way you could figure out what is wrong.
It could not even be related to the downpipe.
Old Jan 10, 2012 | 07:00 PM
LS6Rally's Avatar
yes check the code. i have a 2.5 Catted ZZP pipe and no codes for me. if its an O2 code, reset it and see if it comes back.
Old Jan 10, 2012 | 07:01 PM
cobalt20's Avatar
I did it says the P0240 code and could be large vaccum leak, engine oil leakeage, Engine misfire or Catalytic Converver failed. But the guy told me since its aftermarket Converter it will throw a code
Old Jan 10, 2012 | 07:03 PM
05Slowline's Avatar
p0240 or p0420?
Old Jan 10, 2012 | 07:04 PM
cobalt20's Avatar
P0420 sorry
Old Jan 10, 2012 | 07:07 PM
05Slowline's Avatar
ok well you can get hptuned and block the code or get one of the defoulers that pulls the rear o2 a lil bit out of the exhaust stream
it's throwing it cause the rear o2 is reading too close to what the front one is so it thinks the cat isn't working lol
Elite v1's Avatar
Throw a vacuum gauge on the motor, if nothing is found on there, then its the rear o2 sensor, think about it, you put a high flow cat on the car, the sensor is used to reading a clean exhaust, now that the flow has been altered, it doesnt know what to do.
Old Jan 10, 2012 | 07:12 PM
cobalt20's Avatar
Oh ok thank you guys ill try that and see hopefully it works
Old Jan 10, 2012 | 07:24 PM
05Slowline's Avatar
Vibrant Oxygen Sensor Defouler - Universal Exhaust Items
Old Jan 10, 2012 | 07:58 PM
cobalt20's Avatar
So i can pass Inspection with the defouler and is it a for sure fix do you know
Old Jan 10, 2012 | 08:01 PM
05Slowline's Avatar
most likely that'll solve it high flow cat is give or take if it's gonna throw the code....cheaper than 200 for a tune lol.....you could try to put some washers inbetween the bung and the o2 sensor too doubtful that that'll pull it out enough though
Old Jan 10, 2012 | 08:15 PM
cobalt20's Avatar
oh ok thanks ha
bigdogstokes16
Oct 8, 2015 10:28 PM
dasoftest
Sep 29, 2015 02:14 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
