hid noob
hid noob
pretty much, and im about to finially pull the trigger on some HIDS
what i do know and want :
high/low beams
im going with 5k ( 6k is the limit here, but i dont give a crap if i wanted 30k id get them, a friend has 5k and i like it )
is 55w worth it? or even practical?
no fogs
so this is where im at with my checkout, this look good? do i need to buy low-beam hid kit?
high/low beams
no fogs
If you are going to run HIDs in stock housings you do not want to paint the backside of the housing as it is a bowl style which reflects the light outward. Now if you got a retrofit setup ( my personal recommendation ) you can paint the back
like this
http://img30.imageshack.us/img30/8392/light88812197.jpg
not the reflective part
and 5k 55w hids.
not a good idea?
and this is why im asking guys !!! i dont know...
and 5k 55w hids.
not a good idea?
I 2x the retrofit recommendation and other drivers will thank you for the retrofits over just HIDs in OEM housings.
5000k is a good temp to use for headlights.
Stick with 35w..
Above all else, I do recommend a retrofit, like the others are saying.
AT THE VERY LEAST, use eBay projector headlights.
Getting projectors is definitely worth it. You'll be amazed at how much better a proper setup is at night.
Stick with 35w..
$109? holy jesus that company is making a killing. Check out DDMtuning.com
Nothing is wrong with stock housing. People just like to gripe saying its blinding and painful. I've seen worse though...
The light spread from a HID bulb is completely different than from a halogen bulb, and will glare the living crap out of on coming drivers without a correct cutoff shield to stop part of the light pattern.
Its really easy to build your own retrofits takes 4-6h depending on how knowledgable you are with tools and figuring things out, but Padlock has a how to on here
Love it... Mise well not even drive with lights on at night seeing as how people cry about anything other than OEM lighting. Hell my old man has Sylvania Ultras in his 2010 Silverado and they are brighter than my lights on my car. Almost thought about making the swtich to them over my hids but I like the retro look on my car.
shawnsseries
Sep 10, 2015 08:29 PM
