Hit the dyno.....
Old Jul 20, 2008 | 03:19 AM
Scott.Florschuetz's Avatar
Hit the dyno.....
Printout
http://img413.imageshack.us/my.php?image=dyno1oc6.jpg
Video
http://vids.myspace.com/index.cfm?fu...deoID=38832986
Old Jul 20, 2008 | 03:20 AM
SlowBalt_06's Avatar
mods?
Old Jul 20, 2008 | 03:27 AM
cobaltssTH's Avatar
^^x2
Old Jul 20, 2008 | 03:31 AM
stage2's Avatar
more info would be nice lol
Old Jul 20, 2008 | 03:44 AM
ColeJJones's Avatar
Bannned
i know.... i hate when peeps do that
Old Jul 20, 2008 | 09:40 AM
all4glh's Avatar
This is in his sig on RLF.
Bwoody Solid Mounts
Custom Intake
ZZP Shortie Header
3 Inch Magnaflow Exhaust
ZZP 2.8 Pulley
ZZP GM Stage 2 Belt
ZZP 60lb Injectors
NGK Bkr7e Plugs
ZZP Tune
Old Jul 20, 2008 | 12:43 PM
falke401's Avatar
Isnt that a bit lean for these motors? I thought the LSJ should be tuned to be around 11.8 or so
Old Jul 20, 2008 | 12:50 PM
CobaltSS 16's Avatar
Nice numbers.
Old Jul 20, 2008 | 12:54 PM
lsjwannabe's Avatar
Your correction factor was high. What type of dyno?
Old Jul 20, 2008 | 12:56 PM
mken's Avatar
When I had my car tuned it was getting knock above 11.8 at wot, and I've got essentially the same mods as he does. I surely hope that isn't his true A/F.
Old Jul 20, 2008 | 12:58 PM
an0malous's Avatar
wow. high 13s AFR...thats.....special.
Old Jul 20, 2008 | 01:30 PM
I talked to the company that did the dyno and they said theat we are going to actually hook it up to a wideband, but i was curious......we hooked up a scanner to it and noticed that the ECU is pulling 20% fuel to maintain the 14/1 AF could this be that when it was tuned something was not done right? I also get DTC codes for long term injector trim rich "p0172" thats when it pulls the 20%....any ideas?
Old Jul 20, 2008 | 02:11 PM
an0malous's Avatar
who tuned it?
sounds like they did it with their eyes closed
Old Jul 20, 2008 | 02:13 PM
originaladrian's Avatar
Originally Posted by an0malous
who tuned it?
ZZP.
Old Jul 20, 2008 | 02:14 PM
an0malous's Avatar
dyno tuned? or canned tune?
and do you have the correct mods FOR that canned tune?
Old Jul 20, 2008 | 02:16 PM
Dayta's Avatar
pease dont say its canned....
Old Jul 20, 2008 | 03:33 PM
Umm.................... Its canned....for the mods i have now but i know.......its still a canned tune. Im trying to find someone down here that can tune bu tthe one guy i found flaked out on me.
Old Jul 20, 2008 | 03:49 PM
04redline0124's Avatar
thats alot of hp for a canned tune man...
Old Jul 20, 2008 | 03:51 PM
all dynos will read dif. its a tool used for comparison not to tell how much HP you have.
tis a happy dyno
Old Jul 20, 2008 | 03:54 PM
tis a happy dyno
o i know lol, this is the point i tried to spread to other ppl lol
an0malous's Avatar
i would be extremely worried about how that car is running if i were you.
i would baby that thing until you get tuned.
your lucky you havent popped the motor already with those AFRs.
Old Jul 20, 2008 | 04:43 PM
im just waiting for someone in my area to tune...i got the money just need a tuner. i have about 3000 miles on this tune .
Old Jul 20, 2008 | 06:40 PM
theneelster's Avatar
What's the stoich a/f ratio for the 2.0?
Should be around 13 correct?
Old Jul 20, 2008 | 06:55 PM
Stoich...for the 2.0, actually any car to be exact is 14.7 to 1. The PCM on our cars will +/- fuel to maintin a round 14. This is why i asked how to eliminate the o2 readings because when the car a/f is at 12 the PCM thinks its rich "because of the o2 readings" so it throws a code and pulls the 20% fuel i mentioned earlier.
Old Jul 20, 2008 | 07:36 PM
an0malous's Avatar
sounds like your car isnt going into PE, because those trims shouldnt be active when you go WOT.
eliminating the O2 readings is NOT something you wanna do.
