How do you remove the cobalt's gauge clusters?
Old Sep 20, 2006 | 11:50 PM
streetracinazian's Avatar
Wink How do you remove the cobalt's gauge clusters?
Hey, i was curious how do you remove the cobalt's instrument clusters, maybe if it's easy enough, i was thinking i would change the bulb's colors by caps so it would light up a different color at night!
Old Sep 22, 2006 | 08:59 AM
Redberet's Avatar
Its really easy, use a phillips head screwdriver to remove the two screws in the top of the shroud right above the gauges.
Then remove the two side panels, the ones with the foglamps and the other with DIC controls. There are then two 7mm bolts under those panels along with some metal holddowns you need to snap off. Remove everything and take the shroud off. Be Very careful in removing the shroud not to scratch up your interior.
Next there are 4 bolts holding the entire assy in, take those out, rotate the cluster and remove the harness from the back of it, next remove the cluster.
Next remove the 2 phillips head screws on the back of cluster, and remove the white plastic cover. Now our clusters are not the old fashion ones with bulbs, they have non-serviceable LED bulbs so you won't be able to change them.
The way I did it was to use red cellophane sp? on the back of it to change the color to red. Now to do this you will knock all the needles off the gauges. You will then need to line them back up. The best way to do this is plug the cluster back in, turn power on then line the speedo and rev to 0. The fuel gauge you just have to memorize and hope you got right. You have to do it with the key on engine off. The little motors inside the cluster are not indexed and easily moved so you can't do the old trick of taking a digital photo and putting them back because the needles may not stop in the same place every time.
Old Sep 24, 2006 | 02:07 AM
dude, that's awesome, thanks man!
Old Sep 24, 2006 | 08:11 PM
BlackLS's Avatar
How did you go about popping the needles off?
Old Sep 24, 2006 | 08:16 PM
RJSS's Avatar
Do you know if this is the same for the SS/SC gauges? Also, could you post some pics of your gauges after the install? (if you have any)
Old Sep 24, 2006 | 09:16 PM
rally's Avatar
Yes its the same for the SS/SC gauges because the clusters are the same
Old Sep 29, 2006 | 11:07 AM
Edub83's Avatar
How did you remove those side panels? Flathead screwdriver?
Old Dec 8, 2006 | 09:44 PM
cavingman's Avatar
can someone get a picture of the "non-serviceable" leds?
I may have a solution
edit: anything like this?
Old Dec 10, 2006 | 10:56 AM
Redberet's Avatar
No thats a standard cluster bulb, the ones in the cobalt are High Flux LEDS, at least in my dash. They look like this
http://img.alibaba.com/photo/5049387...ranha_LED_.jpg
Old Dec 10, 2006 | 08:59 PM
hmmmm, any means on how to modify this so i can change my display to blue or red?
Old Dec 11, 2006 | 09:00 AM
Redberet's Avatar
Solder in new ones (blue or red). But then your playing with a gauge cluster, which are usually worth at least $400 so its not recommended by any means.
Old Dec 11, 2006 | 05:13 PM
cavingman's Avatar
ok just curious, thanks
Old Mar 22, 2007 | 01:24 AM
rainman_832002's Avatar
I need to know how to get those two trim pieces off so I can get my white gauges on
Old Mar 22, 2007 | 11:39 AM
Bbby121687's Avatar
if say i was to upgrade my cluster from ls to sc or the regualar ss one would my mileage reset or would everything be fine?
Old Mar 22, 2007 | 01:29 PM
Halfcent's Avatar
I'm old school
Whoa, revival!
Okay, what you all need to read is the same thread. There is a how to on disassembling the dash. That gets you to the cluster and all the other parts you are asking about.
Click here
This one is limited to just a couple parts, but it get you going in the right direction.
As for swapping to a different cluster (like a base 120 gauge to an SS 160 gauge), you can't. The BCM won't recognize it and it won't function.
Old Aug 29, 2007 | 11:31 PM
gashousecobalt's Avatar
heres a solution www.blackcatcustom.com they have gauges in all sorts of colors
Spanky's Monkey
Mar 7, 2016 06:06 PM
twilson380
Sep 14, 2015 10:52 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
bustaSS
Sep 3, 2015 09:33 PM
