HP calculator
Old Aug 11, 2007 | 07:20 PM
Belto's Avatar
HP calculator
I find this HP calculator, it may help a bit for all those people that will want to know there 1/4 mile time before going..
http://carrito.net/hp_calc.htm
hope it helps
I think this help, you put your weight, and your HP and they give you your 1/4 mile time... anyone?
Old Aug 11, 2007 | 07:54 PM
stryder's Avatar
good find
Old Aug 11, 2007 | 08:45 PM
Belto's Avatar
^^^ thanx, hope it helps people
Old Aug 11, 2007 | 08:52 PM
88cobaltSS's Avatar
about how heavy is an SS/SC
Old Aug 11, 2007 | 09:10 PM
Blown 4-banger's Avatar
Its not very accurate. I tried it for a Z06 corvette, 3132 lbs, with 505 hp. It shows 11.27. The best best best drivers get like 11.5-11.7. You would need DRs to run 11.2. Then for a decently modded cobalt, 2800 lbs, 260 whp = 12.86!?!?
stryder's Avatar
about 2900 lbs
Old Aug 11, 2007 | 10:59 PM
Belto's Avatar
the balt weights about 2900 + 260whp= 13.014799 ... to that add your weight, also that will be with perfect shifting// plus its just an estimate...
Old Aug 11, 2007 | 11:15 PM
DarkSergeant's Avatar
260 whp is a lot for a cobalt. Stage 2 is what 240ish?
Additionally - I'd say its 2900, plus your weight, plus about another 150 lbs of stereo, plastic and other assorted crap.
Old Aug 12, 2007 | 01:04 AM
SSBalt's Avatar
It is fun to use. But wasn't very accurate on my blown 92 mustang. Said I was a 13.5 and I pulled a best of 12.9 on street tires (and first time at the track). Granted my first run was a 13.7 lol. But the program shouldn't include driver retardedness-just car capability. Then again. Maybe the dyno I was on didn't give my car justice. Who knows..the whole thing is a crap shoot. But it is a blast to plug in the numbers. Hmm..Wonder what my 2.4 is capable of? Ok...switching websites now...
Ok.. I see it's a different caculator. I retract my statement
Old Aug 12, 2007 | 01:07 AM
Littlegoose's Avatar
My SS/SC at 228whp and 3k lbs said a 13.75 in the 1/4........I doubt it.
Old Aug 12, 2007 | 01:09 AM
chevysalesman614's Avatar
2911 DRY!(cobalt) so figure in the liquids, and driver weight too... then it will be close. with my actual race weight, and hp, it came out within 3 tenths of my real time
Old Aug 12, 2007 | 01:13 AM
LE5CAV's Avatar
this is not very accuerate because it does no account for gearing, torque, redline, tire size, traction, or drag
Old Aug 12, 2007 | 01:17 AM
mIkeyG312's Avatar
exactly wut i was thinking i mean it could be a little more accurate if they at least added torque in there but still for what it is its pretty close
Old Aug 12, 2007 | 01:19 AM
SSBalt's Avatar
Agreed. Very basic caculator. Never seen one that includes drag though.
Old Aug 12, 2007 | 01:27 AM
Belto's Avatar
its just an estimate,, to give you an idea of were your at...
Old Aug 12, 2007 | 01:41 AM
jimbos'ss's Avatar
hahahahaha at 10000 wheel hp a cobalt could run a 3.85
Old Aug 12, 2007 | 02:32 AM
HViper's Avatar
Acorrding to this I shoud be running almost a 13.00 flat right now. 254 WHP + 2900lbs = 13.116481673676222
Once I add the rest of the parts I have in my closet I will be running a 12.932425076455242
Does this thing account for traction, or more like the lack of???
Old Aug 12, 2007 | 03:35 AM
Blood Lucky Picnic's Avatar
Its a neat concept tho. Needs work but neat none the less.
Old Aug 12, 2007 | 04:41 AM
ItalianJoe1's Avatar
Don't figure it at 2900 pounds, probably closer to 3200. Car should be 2991 according to most sources, add at least 150 for driver, thats average weight when figuring a person, and whatever crap you might have in the car, stuff in the glovebox, trunk, whatever. Full tank of gas= 80 pounds, so even that plays a part. At 3200, with my stock dyno# of 217, that sounds about right. Now, with i guess 245-250, thats mid-upper 13s, which I think is ok. 292hp gives me 12's, which is what i'm hoping for. Its a fun thing to play with actually.
Old Aug 12, 2007 | 04:45 AM
justin04's Avatar
I weighed my car last night... at a farmers market where they weight in trucks and semi's and with a full tank of gas and me (210lbs) with 2 12's in the trunk it weighed in at 2998 lbs
i mean this is a accurate scale...
Old Aug 12, 2007 | 05:09 AM
c0ld29's Avatar
I would say this website would be better to get a good HP estimate after running at the track. After all... all dynos are different, but a 1/4 mile is still a 1/4 mile
Old Aug 12, 2007 | 08:19 AM
firemanfrank's Avatar
Huh?
2998 (the scales you tested on)
-210 (your weight)
2788
-50 (2 encased 12's?)
2738
Now if we subtract 1/2 tank of fuel (most car tests run a 1/2 tank of gas):
1/2 of 13.2 gall. = 6.6 gall
6.6 gall. fuel @ 6lbs./gall. = 40lbs.
2738
-40
2698lbs.
2698lbs.?
I' havn't seen a single test of an SC where it's test weight was less than 2911. There seems to be a 200+lb. discrepancy here. ???
(examples below from road tests)
Motor Trend 2959 lbs.
Car and Driver 2911-2936 lbs.
(2 different tests)
Therefore, using our car's realistic 2950lbs., plus my 230lbs., equals 3180lbs. (1/2 tank fuel, no stuff added to/removed from the vehicle, etc.)
So plugging 3180 lbs. into that calculator shows I was making 223hp at the crank on my box stock SC when I raced the car new (I ran 14.87 1/4 mile)
That seems right ...
Old Aug 12, 2007 | 09:54 AM
That market is keeping the farming man down.
Old Aug 12, 2007 | 10:14 AM
Jackalope's Avatar
Its not that far off. It has my Balt in at a 15.2 which is about where I'm running. If your getting Waaaaaaaay goofy numbers your putting in bad info.
But yeah its not perfect its an estimate.
Old Aug 12, 2007 | 11:12 AM
Belto's Avatar
yes. it just a fun estimate, nothing to BRAG about, if you want to really know go to the track..
chefhhr
Oct 26, 2015 10:36 PM
patooyee
Oct 15, 2015 05:11 PM
N8s07SS
Nov 3, 2006 12:59 PM
