If i was to get tuned...
I also read you can delete the rear 02 sensor during tuning. Will this affect my e test? also is it okay to use the post-cat 02 bung for a wideband as far as tuning is concerned
you wouldn't need to remove the cat, but I would place the wideband before the cat so you're getting the afr readings out of the block. Only reason for the rear o2 is to ensure that the cat is working.
Not sure how they do emissions testing in canada, but here in texas, they hook up at the ob2 and read the readiness codes. If there's more than two readiness monitors that are off, you fail. That, or if you have any cel's.
so long story short i should go get another 02 bung welded in pre cat?
in ontario im pretty sure they just check your emissions coming out of your tail pipe, however we are switching to the obd 2 system in the next year or so
I'm not sure why you would have to weld another bung. I've always thought stock ss exhausts had two o2 sensors (one pre-cat, and one post-cat). Then again, I haven't had a stock exhaust for a bujillion years....
obd2 scan. welding in a bung takes like 5 min if you take the dp off you car and either do it urself or bring it to a shop. The downpipe has a sweetspot far enough off the header and just before the cat which works perfect and would compromise anything.
Ps: all catted down pipes stock or aftermarket has 1 pre cat and 1 post cat to tell the car emissions are working
Right.......I guess AEM is lying also?
http://www.schnitzracing.com/manuals/AEMWBK.pdf
"For accurate readings, the sensor must be mounted before catalytic
converters and/or auxiliary air pumps."
Innovative must be liars and incompetent idiots also right?
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
"On CATALYTIC CONVERTER equipped vehicles:
Install the oxygen sensor’s bung upstream from the catalytic converter"
that's funny, they both have the same placement
WOT it will skew it less, cruising will throw it off the most.
Install the oxygen sensors bung upstream from the catalytic converter"
Im saying my WOT AFR is tuned at 13.5, and I see 13.5 on my wideband. My cruising AFR is 14.7 (i see WOT AFR at 90 something percent throttle)
