Inaccurate Speedometer
Has anyone else been having problems with there speedometer being inaccurate? I have had 2 people follow me on the highway. When my speedometer says I am going 75 I am really going 70. And when it says I am going 85 I am really only going around 79. I have taken it to the dealership and they pretty much said that there was nothing that they could do. Does anyone have any suggestions?...besides kicking the service manager in the nuts
That's a new one, never heard anyone complain of it before
It really cant be out that far, unless somethings changed like tire size.
What do you run for tire pressure?
All the dealer can do is reflash your PCM (where the speedo calibration exists) in case it's corrupted somehow. (assuming you are using the factory tune of course and not HPT or something like that) or maybe replace the speed sensor in the transaxle but if the speedo's working the VSS is as well. Weird
Wop
Edit: Come to think of it- I would have someone maybe use a scan tool to compare the PCM parameter for Vehicle Speed to the indicated speed on the gage in the cluster. Maybe there's something wrong with the cluster
Wop
Wop
Wop
Originally Posted by bredick
Well, it'll save you from getting a ticket, are your tires stock or at least the stock size? Clutch slipping?
If I knew that my speedometer was off by 5 miles an hour, I probably wouldn't have bought it.
Originally Posted by chipmonk212121
32 psi on 18's... where are these specs at? last time I checked when I had my 245/40/18 on my grand prix my psi needed to be at about 40
specs are on your door...mine are at 26-27 psi right now (oops) but im going back up to whatever it says on the doorpanel tomorrow.
Originally Posted by automobiliben
Ohh, tire pressure is the recommended 32 psi. But like I said everything is stock. There would have to be something majorly off to account for the 10% discrepency (sp?).
Mine reads to fast as well, I was reading 130 and friends were at 122 or so.
It's just a **** off cause km's are going on quicker then they should, which is the reason my next tires will be a little bigger 225/35.
I havent bought a car mag in forever,but all of the bike mags that are worth a damn give you the speedo error at 30 and 60 mph.Sometimes at 60 its around 3-4 mph and just keeps going up the faster you go.Now ,as to our speedos, I have no clue how acurate they really are.Ask a cop to help test it.
