ingalls vs solid engine mt
Old Jul 29, 2008 | 11:18 PM
Inferno's Avatar
i have a ingalls td on the car right know set to the stiffest setting. would a solid upper engine mount make much of a differance. the reason i ask is i have been racing alot at my local track lately and my traction is bad, but i don't want to run radials so i'm looking at other traction options.
Old Jul 29, 2008 | 11:23 PM
schamsy's Avatar
Do you have wheel hop?
Old Jul 29, 2008 | 11:26 PM
cblt12's Avatar
you should look into poly tranny mounts before you change the motor mount, since you already have the ingalls... i have the ingalls w/ tranny mounts and i get only spin on the street and just slight hop on the track.
Old Jul 29, 2008 | 11:27 PM
NinjaHampster's Avatar
if your looking at the TTR top engine mount it will not work with the ingalls. but the solid mounts will not bend like some members have had with there ingalls.
Old Jul 30, 2008 | 01:25 AM
theneelster's Avatar
Difference is that the torque dampener actually has cushioned movement whereas a mount doesn't. If you get the upper mount you need the tranny mount at the very least.
Old Jul 30, 2008 | 01:27 AM
silentd's Avatar
big difference IMO, ive had both and played with both... solid ftw
Old Jul 30, 2008 | 01:29 AM
bridfi's Avatar
the mounts are awesome. get all 3 and ditch the ingalls
Old Jul 30, 2008 | 01:32 AM
CobaltLs_14's Avatar
Go with the mounts...
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
footballplaya3k
Sep 30, 2015 09:39 PM
DocSvensk
Sep 27, 2015 02:24 PM
