intake resonator, HELP!!! have a problem
well i tried to take out the resonator.
i took out the head light and unplugged it.
took off the headlight braket.
took off the top of the air box but couldnt get bottom cause i coould not reach the star screw at the bottom of the box.
and couldnt get the "bong" out.
so i said **** it and put the air box back together, then the headlight bracket. then i put headlight back in and hooked it up and made sure that worked.
NOW THE BIG PART, i was moving it out of the garage and cleaning it up and NOW my CHECK ENGINE light is on and wont go off!!!!
any ideas
any ideas
isnt it in the trunk?
i know im a noob, im 16 and just got this car in sept 08
i work at a garage and have to take apart headlights and taillights all the time when they burn out for inspection
Last edited by cwalters2628; Jan 14, 2009 at 12:26 PM. Reason: Automerged Doublepost
x2 if you want to take it out you gotta drop the fender.......its not hard its just a plastic piece....
go in through the fender..........it should take you 20 min to take it off and put it back........trust me ive had mine in and out 6 times cuz of my lambo door install
thats what im doing, i have done minor things so far, but when my brother comes in they said i could do some stuff cause he has a balt ss/na and knows what he is doing
can you explain how you go through the fender?
Last edited by cwalters2628; Jan 14, 2009 at 12:36 PM. Reason: Automerged Doublepost
Well you don't have to take off the wheel just turn it a bit to get to the fender easier. I think it would be less obvious than taking the headlight anyway. It's just some bolts then pull the fender well back a bit to get to the snorkel.
thats what you want to take out......there are tabs that you pop out and a few bolts......just look at it and find all of them
once you remove them the plastic piece drops out..........then you have full access to everything you need
just be careful reinstalling............you have to get the plastic piece back in the lip of the fender
is that what you needed or do you need clarification?
GET THIS ****!!!!! i start driving down the road and the check engine light went OFF!!!
but i went to the garage and waldo said just reach your hand down in where the star screw is and just pull up. so im gonna do it tomorow.
Now how do i get the screw out that is holding the bong right under the headlight?
OrangeCoba
Sep 25, 2015 06:06 PM
