Jacking up your Cobalt
Old May 24, 2006 | 12:20 PM
b-spot's Avatar
I forgot to post this up when I changed my wheels.
When I put my winters on I got the car up and down no problem.
Doing my summers however, on the front passenger side the ridge just inside the sideskirt that you use as your jackpoint bent down!! WTF??
Anyways, where the hell do I jack it up now?? On the flat spot right next to it?
Old May 24, 2006 | 01:55 PM
tiny's Avatar
why not use the frame?
Old May 24, 2006 | 02:01 PM
SS33's Avatar
^^what he said, just get a real jack and use the frame as your lift point. After seeing a few threads on the stock jack failing I wouldn't trust it anyways.
Besides, compared to what you dropped on the car, the money spent on a better jack could be considered a wise investment.
I assume you are using the trunkjack if you are lining up on that ridge,,, if you are using a real jack, then that is why that ridge collapsed.
Old May 24, 2006 | 07:35 PM
b-spot's Avatar
Lol... ****.
I am using a real jack. It has notches though, so I lined that up. I guess now we know why my ridge is bent. Should I jack on the frame right next to the ridge?
Old May 24, 2006 | 07:38 PM
skoshi130's Avatar
on the forward edge of the frame it is reinforced. You will see additional material in that area
Tomtwtwtw's Avatar
Originally Posted by b-spot
Lol... ****.
Haha...I did the same thing to my Pontiac. The frame right next to the ridge will do fine. That's technically where the trunk jack should put pressure, anyway. The J-shape on it just sits over the ridge.
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
QuickSilver_SS
Sep 17, 2015 05:38 PM
