L61 vs LSJ
Old Mar 13, 2006 | 02:14 PM
shadowmaster05's Avatar
Exclamation L61 vs LSJ
Just curious, my buddy has a 05 cobalt LS, what is the diffecne in the engine from the SS? is the whole layout different? or is it just the compresion and the stroke? i been talking to him. im upgrading the turbo on my 300zx, and i am going to have that one left over. what would happen if we put the turbo on his? would we need to lower the compression or what? just curious. let me know. thanks
Chris
Old Mar 13, 2006 | 02:16 PM
CobaltBurst's Avatar
LS=2.2L SS/SC=2.0L(Built For Boost) SS/NA=2.4L
So yes they are very different engines...
Old Mar 13, 2006 | 02:19 PM
MarcS's Avatar
The Stig
Coupe LS:
145-hp 2.2L engine
Getrag five-speed manual transmission
CD player
15-inch wheels and Touring tires
Premium Ride suspension
Coupe LT:
145-hp 2.2L engine
CD player
Cruise Control
15-inch aluminum wheels and Touring tires
Coupe SS:
171-hp 2.4L High-Output engine
17-inch aluminum wheels and Sport tires
CD/MP3 player
Seven-speaker Pioneer premium sound system
Tuned Sport suspension
Coupe SS Supercharged:
205-hp 2.0L Supercharged engine
18-inch aluminum wheels and Z-rated tires
Five-speed manual transmission with short-throw shifter
Leather-appointed front bucket seats with color-keyed perforated inserts
Performance Handling suspension
Old Mar 13, 2006 | 02:22 PM
avro206's Avatar
LSJ has the forged internals to handle more boost, engine oil coooler, piston oil jet squirters--well thats a start anyhow.
Old Mar 13, 2006 | 02:31 PM
so other then a few slight mods to it, his car should be able to handle a turbo with like 6 psi w/out much put into it?
Old Mar 13, 2006 | 02:43 PM
c7015's Avatar
if internals are slight mods ... It really depends on how much boost he wants to run ..
Old Mar 13, 2006 | 02:51 PM
not alot, just to get some more power i guess.. maybe max boost of like 10psi. just you know, knowing that you can do it i guess..
Old Mar 13, 2006 | 02:54 PM
c7015's Avatar
you can pretty much do anything ...it just depends on how much time and money you want to invest
Old Mar 14, 2006 | 03:07 AM
CobaltCoupeCrazy's Avatar
Exclamation
Actually, the LSJ and L61 start out the same. The LSJ is just destroked (allowing higher rpm) and given all of the high strength internals and other parts to handle the boost and provide long term durability.
Scott
Old Mar 14, 2006 | 11:07 AM
Halfcent's Avatar
I'm old school
you seem to have 2 questions. The first is is difference in the engines.
LSJ:
destroked crank for 2.0L displacement
forged crank and rods, dished pistons
piston oil cooling jets
oil cooler
sodium filled exhaust valves
capable of about 300 HP safely without modification
capable of about 400 HP safely with piston swap
L61:
Regular crank for 2.2L displacement
cast crank and rods, flat pistons
Passages for oil jets are cast into the block, but no jets are installed
oil cooler provisions are cast into the block, but not installed
solid valves
capable of about 250 HP safely without modification
capable of about 450 HP safely with rod and piston swap
Your second question had to do with the turbo. You could run about 8 psi on the L61 and stay under that 250HP safe limit. You ofcourse will need some kind of computer to control that thing however.
Old Mar 14, 2006 | 11:24 AM
FAST06SS's Avatar
The heads are not interchangable either. So even though it looks similar, it is very different overall engine!
Old Mar 14, 2006 | 12:38 PM
zinner's Avatar
Moderator Alumni
If the old turbo has a T3 flange you should be able to grab the log maifold off ebay. There is a guy who sells a T3 turbo manifold for the 2.2 ecotec.
There isn't a big choice of off the self turbo manifolds for the ecotec that I have found.
Old Mar 15, 2006 | 12:35 PM
yeah its a T3 off my 300ZX so, but thanks for the help many many thanks
Chris
Old Mar 15, 2006 | 01:36 PM
mycavisux97's Avatar
tell him to trade it for an ss/sc
Old Mar 15, 2006 | 01:39 PM
memphisr24's Avatar
Dude, take my advice and buy the GM Build Book. It will show you everything you need, all the parts, to build the 2.2 up to 250hp, 400hp, 600hp, 1000hp, and 1400hp.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
