lambo door help
most every car that you do the bolt on kit you have to roll or cut the fenders. Make sure that you make the wires long enough but keep the out of the way of every thing. The thing i dont like about the bolt on kits is that they seam to need adjusting alot more often.
the only place you will have to cut is where the hinge swings up and down. U will know exacly where once u get the henge and door on and adjusted the u carfully place the fnder on and mark where the henge hits. Then cut it carfully and test fit if u still need more triming then trima again and so on. it is really very easy to do just take ur time and tape off the edge of the door, edge of the fender,really any place that might rub this will help keep from messing up the paint. Good luck and post up some pics.
satisfied
10-19-2015 12:35 AM
