lbs/min MAf
Old Jul 24, 2009 | 09:58 AM
victoryss's Avatar
lbs/min MAf
Wondering how much air you tuned lnf guys as well as turbo swapped lsj's are pushing
Old Jul 24, 2009 | 11:38 AM
Wickedlsj's Avatar
33 without an intake at 22psi, I've heard rumblings of 36-38 with an intake and same boost pressure.
Old Jul 24, 2009 | 12:00 PM
Darkmanx's Avatar
It changes when you ajust your maf.
Old Jul 24, 2009 | 12:08 PM
Area47's Avatar
Rent me! per hour
47.63 @ 7900
Old Jul 24, 2009 | 12:10 PM
victoryss's Avatar
Originally Posted by Area47
47.63 @ 7900
DAMN That on the 2.75" or 2.9"?
Mines showing 43.41@7200
Old Jul 24, 2009 | 12:19 PM
Area47's Avatar
Rent me! per hour
man pulley
Old Jul 24, 2009 | 12:25 PM
Darkmanx's Avatar
mine use to say 43 but when i swap to the 79lb its at 38lb now
Old Jul 24, 2009 | 12:33 PM
Pyros777's Avatar
Stock SS T/C before tune: 29.56 @ 6335
Stock SS T/C after tune: 31.68 @ 5952
GM S3 SS S/C: 29.25 @ 6533
Old Jul 27, 2009 | 08:42 AM
Wickedlsj's Avatar
47.63 @ 7900
Oh the parasitic loss...
Old Jul 27, 2009 | 12:21 PM
06blackg85ss's Avatar
56.66 @7900 rpm...... on 26psi
it was reading anti freeze after that lol
Old Jul 27, 2009 | 12:47 PM
victoryss's Avatar
lawl. and wow that thing must have been FLYING down the road
Old Jul 27, 2009 | 12:56 PM
it was til I went to grab 4th
Old Jul 27, 2009 | 01:00 PM
damien's Avatar
Then boom!
Old Jul 27, 2009 | 04:03 PM
Tennpenn83's Avatar
35.45 lbs/min @ 6700rpm
tvs with stock 3.1" pulley
Old Jul 27, 2009 | 04:06 PM
EXsoccer1921's Avatar
69lb/min@6900
Old Aug 10, 2009 | 06:57 AM
ralliartist's Avatar
38lb/min @ 7200
Old Aug 10, 2009 | 05:03 PM
rukkee's Avatar
You guys are moving alot of air . The most i've seen is 30.89 lb/m lol.
Old Aug 10, 2009 | 05:11 PM
BLAZIN07SS's Avatar
I'm too JDM for you
when it was modded i hit 37.61 lb/min
Old Aug 10, 2009 | 05:14 PM
06black's Avatar
with a few key hits, i can make a car read 67+ lb/min or 27lb/min its all in the cal.
dont put much stake in maf numbers, unless you know the cal and can compare apples to apples.
Old Aug 10, 2009 | 05:18 PM
victoryss's Avatar
Good thing I am an apple expert
Old Aug 10, 2009 | 05:19 PM
Area47's Avatar
Rent me! per hour
just because you fucked up your own map doesn't mean the rest of us are off base
jackass
Old Aug 10, 2009 | 06:16 PM
06black's Avatar
jackass
ohh but it does you tool chest! None of these half-Witts take the cal into consideration.
My map worked with my pe table, idiot!
If I see one more lnf tart useing maf flow for power calcs, I'm gonna snap.
Your still slowwwwwww.
Ps-we need a squirell trip to JP's again. **** that was fun!
Old Aug 10, 2009 | 06:18 PM
1badBlueberrySC's Avatar
I usually see 31-35 lb/min! With a pissed off turbo
VE airflow shows about 30-31
Old Aug 10, 2009 | 06:19 PM
Area47's Avatar
Rent me! per hour
bring your cute little roid injected lsj down here to my neck of the woods. i'll show you slow.
yes. fall time road trip needed
Old Aug 10, 2009 | 06:21 PM
Spectral's Avatar
Get a new turbo
