Limp Mode underboost please help
Old Dec 5, 2015 | 11:46 AM
Ohio SS/TC's Avatar
Im just going to throw this out there to a broader audience.
I have a 2008 Cobalt SS (turbo obviously) with a Typhoon air intake. *bought it this way.
I have been getting a randomly occurring P0101 code in the pending. Seems to happen more frequently with the outside temp dropping. I have done the boost leak test and I didnt find any leaks except a very tiny sound of air coming through the PCV valve.....just a very tiny amount.
I hook up my code reader/scanner while I'm driving now on a regular basis....as soon as it goes into limp mode (wont boost above 4PSI) I clear the pending P0101 and it goes back to *normal* around 15PSI. Sometimes when I am on the highway and it happens I will clear the code and it will boost up to near or at 20PSI.
I replaced the MAF just to eliminate that possibility and its still happening.
Anyone else ever experience this and if so what might fix it?
Old Dec 5, 2015 | 12:05 PM
Well I would say to atleast try and fix that pcv valve leak and keep looking if it still happens after that
Old Dec 5, 2015 | 12:06 PM
Ohio SS/TC's Avatar
Yeah got one coming in from GM parts direct
Old Dec 5, 2015 | 02:47 PM
Cool let's see if that helps
Old Jan 5, 2016 | 02:34 PM
Ohio SS/TC's Avatar
Well PCV tube/check valve replaced...still getting the dang P0101. Cant find a boost leak at all. Car seems to go into limp mode only while idling occasionally, or while cruising on the highway.
Old Jan 5, 2016 | 03:04 PM
That's the only cel you have?
Old Jan 5, 2016 | 03:15 PM
Ohio SS/TC's Avatar
yeah and it seems to always stay in the pending, but as soon as it happens the car goes into limp mode it won't boost above 5 psi, luckily I keep my scan tool handy all the time so when it happens I erased the code real quick and it'll boost up to 20 psi for about 5 or 10 minutes before going back to the stock 15
Old Jan 15, 2016 | 01:38 PM
Ohio SS/TC's Avatar
Noticed that my fuel trim LTFT is at 20-21
iammancini
Canadian Mid East
Jun 19, 2016 10:33 PM
Joshua Sloan
Dec 25, 2015 10:34 AM
Chris06CobaltSS
Dec 7, 2015 02:14 AM
Usmc_arty
Dec 1, 2015 12:28 AM
janinexxmariee
Nov 29, 2015 02:58 AM
