Need Help!!!
Old Feb 22, 2008 | 10:36 PM
PsychoCam's Avatar
Need Help!!!
I am putting on the 2.0SS dp on my 07 2.2 and I noticeed I have 2 oxegyn sensors 1 before and after the cat. the ss dp has only one after the cat. Which connector do I plug the new oxygen sensor into? and waht do i do with teh other one.
Old Feb 22, 2008 | 10:38 PM
XM15's Avatar
You're sure you don't have SAI?
Old Feb 22, 2008 | 10:42 PM
PsychoCam's Avatar
I dont have sai b/c it was not on my factory airbox when I put my injen cai on. i am so confused
Old Feb 22, 2008 | 10:44 PM
Sunburst_SS's Avatar
the pre-cat o2 sensor bolts into the exhaust manifold, not the down pipe.........so the down pipe should only have 1 o2 bung in it.
Old Feb 22, 2008 | 10:48 PM
PsychoCam's Avatar
No i dont have any o2 sensor on my header. idk what to do
Old Feb 22, 2008 | 10:50 PM
you might want to take a second look.....
Old Feb 22, 2008 | 11:45 PM
PsychoCam's Avatar
took second look and no 02 sensor on the header
Old Feb 22, 2008 | 11:48 PM
should be under the heat sheild. right next to the flange
Old Feb 22, 2008 | 11:50 PM
steiny69er's Avatar
Guys on the 07's the 02 is deleted from the manifold and is before that cat on the downpipe.
Old Feb 22, 2008 | 11:56 PM
PsychoCam's Avatar
Yes exactly so I have only 1 02 sensor hooked up right now
Old Feb 22, 2008 | 11:59 PM
so you do not have the pre-cat o2 sensor hooked up?
Old Feb 23, 2008 | 12:01 AM
PsychoCam's Avatar
No i did not hook it up b/c there is no place to put the oxygen sensor.
Old Feb 23, 2008 | 12:03 AM
then your car will pretty much go into safe mode, command a rich fuel trim and your gas mileage will not be as good
