need help foglights
Old Sep 6, 2013 | 11:59 AM
2010CobaltLTfan's Avatar
need help foglights
Im putting my ss bump on my lt soon I need foglights my car didnt come with factory foglights I see everywhere where you can buy just the foglights but I need the factory wiring also where can I get the wiring and the inside trim piece for the fogs
Old Sep 6, 2013 | 12:20 PM
Sox-Fan's Avatar
Got Brakes?
If you check under the headlights you will probably find that the wiring is already there.
Old Sep 6, 2013 | 12:24 PM
Really damn I have to check my luck its not
Old Sep 6, 2013 | 12:32 PM
Sox-Fan's Avatar
Got Brakes?
Pretty sure that GM uses the same wiring harness for cars with and without fog lights.
Old Sep 6, 2013 | 01:38 PM
I hope so because that would save me so money
Old Sep 6, 2013 | 02:44 PM
I looked and I didnt see anything does anyone know where I can get these parts
Old Sep 6, 2013 | 03:03 PM
Get a hid set up and wire that to a switch, just make sure its a fused switch or add a fuse between the battery and switch.
Old Sep 6, 2013 | 03:14 PM
mkulrey13's Avatar
I have a few PnP kits left. Includes Foglights, Wiring Harness, and also a HID Kit. Harness is made so they come on with the car and off with the car. Perfect for those who disable DRLs!
Old Sep 6, 2013 | 03:21 PM
andrewcarr1993's Avatar
Who's taking over hidwerks Mike?
Old Sep 6, 2013 | 03:28 PM
mkulrey13's Avatar
No one, I just refuse to pay for a terribly run website lol MOD choices are aweful and nothings done about it
Old Sep 6, 2013 | 03:30 PM
Okay so you're still running hidwerks.com just not going to be a vender on here.
Old Sep 6, 2013 | 03:37 PM
mkulrey13's Avatar
No vendor, Only Facebook but im clearing my stock so everything is dropshipped. Look for DEALS
Old Sep 6, 2013 | 03:57 PM
I want to run a stock setup with the foglights like stock wiring and stock button but want to run hids
Old Sep 6, 2013 | 04:02 PM
Haven't looked at the stock button, but you could probably wire to it, just use the correct gauge wire, there is no reason to spend a bunch of money and time to install a wiring harness that has the foglight wires if yours doesn't already. Use the correct gauge wire for the amps it will pull and you'll be fine
Old Sep 6, 2013 | 04:40 PM
I will do anything to just keep it almost factory looking as much as I can
jasonaudio
285
Nov 10, 2008 07:06 PM
VeNoM0713
Jul 29, 2007 05:13 AM
Orange06Supercharged
Oct 24, 2006 11:30 AM
Dustin
Sep 1, 2006 10:12 AM
GotBoost?
Jan 9, 2006 12:32 AM
