Need help please!
Old Sep 2, 2008 | 07:25 PM
YELLOW_REVOLUTION's Avatar
Need help please!
first off im not sure if this is in the right area... so if need moved can it be.
ok took the headlights out to paint eyelids... went great...
have had eyelids on for about 4 months now... yet again... great...
the past week or so its been foggin up from the freakishly humid days were gettin in ohio.. well i being a dumba$$ pulled it into my Cooler temped garage and left it over night... all the moisture turned to water... splashed the light and broke the bulb... what is the easiest way at fixing this...
1 take the whole plastic clear facing off and re-attach
2 look for seal break and seal again
3 (i doubt this would work but who knows a friend told me) drill a hole under the casing?
4 suck up to the wife and use some leftover money on my second largest paycheck of the year and buy halos? (my fav option)
5 your suggestions if im totally off the charts here... but if i cant do the halos what should i do i stil need an out just in case
Old Sep 2, 2008 | 07:29 PM
REIGN SS's Avatar
Original Hayden Fanatic
take the bulb out and shake the pieces out of the hole.
yeah but how about the water moisture it will just keep shattering it whenever it gets wet right?
Old Sep 2, 2008 | 07:33 PM
Firebirdhorn's Avatar
do what reign said, then re- seal the headlight with some silicone....good as new. By the way, could we get a full frontal shot of the car? That first pic looks pretty bad ass.
Old Sep 2, 2008 | 08:08 PM
ok here two outer shots.. and i figured being a rev ed yourself you might like the interior in case you decide to paint heres an idea
and heres the interior pieces so far
Old Sep 2, 2008 | 10:15 PM
man....that is kick ass.....i like the way you put the strips in the car......good idea
Old Sep 2, 2008 | 11:00 PM
wardzach2007's Avatar
Bake the housings in a oven, clean them out and put back together with silicone.
