Oil Consumption
Oil Consumption
Hi,
After watching my oil levels for a while, I've determined that my car (05 2.2L) goes through a quart of oil about every 850 miles. The engine has almost 170,000 miles on it. It doesn't leak, and I don't see any smoke, but I am just assuming that it must be burning it at a rate that doesn't cause it to smoke. I just want to make sure that this amount is normal for my car and that I don't need to be worrying too much! I run 5W-30 full synthetic.
Thanks!
Thanks!
Hi,
Thanks!
Thanks!
But yea you are definitely using more than you should. If your cat is healthy it will burn off quite a bit of excess oil without letting it smoke, that is until it starts getting carbon fouled.
