Oil leak
The very end cap to the right has a rubber gasket if I remember correctly. But once you take off the end cap the top cap, with the two bolts you can see in the picture, doesn't use a gasket and is only sealed with a little bit of anaerobic sealant. This shouldn't really need done unless you have had someone do cam work.
