Oil leak, Help please
Old May 30, 2017 | 07:51 PM
Estephens13's Avatar
Hi,
I am trying to figure out where the leak is coming from. I can see fresh oil to the left of the alternator (pictured), but I'm not sure where its coming from. Any ideas? Thanks in advance.
Old May 30, 2017 | 08:02 PM
Tdubbs's Avatar
It kind of looks like it's getting flung around, possibly the front crank seal. Only real major oil sealing gaskets around there are the valve cover, timing cover, and front crank seal. You may need to wash down the front of the engine, and check frequently to see where it's starting to leave fresh stains.
Old May 30, 2017 | 08:04 PM
I assumed it was the front crank seal and did that last weekend. still leaking.
Old May 30, 2017 | 08:18 PM
Tdubbs's Avatar
I'd wash everything down again and check it all out some more. It could be the timing cover or the valve cover leaking down, but if the crank seal was nicked when the crank pulley was reinstalled or not installed straight enough it can and will leak.
Old Jun 2, 2017 | 10:00 PM
Update, I found it. Unfortunately its a crack by the hoist location on the head.
Old Jun 2, 2017 | 10:20 PM
Tdubbs's Avatar
Wow, I've never seen that before, that sucks man.
I know it's not aomething you wanted to have to do, but at least you can pick up a head fairly cheap for the car.
