P0411 and Engine Power Reduced
Old May 3, 2017 | 01:38 AM
Boujii's Avatar
Hello friends,
I've been having 2 issues from time to time. I am getting the P0411 Secondary Air Injection System Incorrect and Engine Power Reduced. This past weekend I cleaned the throttle body out spic and span. It had some grunge so I thought the problem fixed. Yesterday it happened again. Sometimes it will re-start and idle fine while other times it just does the same thing on restart.
When I check the codes I get the P0411 code only. Last night I took the throttle body off and inspected it. The sensor in built into the side of it so complete disassembly is was not possible for me at that time. I did take the clips off that hold the sensor and 6 (or 8 ) pin electrical connector and blew in some air from the compressor and sprayed some throttle body cleaner in there and air dried again.
This morning it started fine. So I tried to replicate the problem by shutting it off and back on a few times. It idled for about 10 seconds and then shut off. I checked the code and got the P0411. As usual when I get the P0411, I start it back up again fine. So my question is, do I have 2 separate issues or is the p0411 causing the reduced engine power (or vice versa). I believe every time I get the Engine Power Reduced, I also get the P0411 code.
I believe my throttle body is on it's last leg. I say this because I can now physically hear the butterfly or something else clicking on it when I turn the key. I mean loud enough to hear it inside the car when I never heard it before.
I've been reading some posts and got a diagram of the secondary air injection system in a post for someone else.
Looking for some advice before purchasing another throttle body or an air injection system.
Thanks my friends,
Jeff
Old May 3, 2017 | 11:28 AM
jdbaugh1's Avatar
If your throttle body position sensor was reading different than where the computer expects it to be that should throw a throttle body position sensor code. I had an issue with my TB harness connection point getting wet and it threw me into engine power reduced mode but I also had the code for the TB position. Is the only indication of TB problems the noise it makes?
I don't know much about SAI but it appears there are a number of things that can cause it. Fuse, pump or check valves is what I found people typically check with this code after a quick google search.
Old May 3, 2017 | 12:39 PM
Boujii's Avatar
Yes the noise is the only indication that it might be the TB. From most posts I seen, the engine reduced is usually caused by the TB being dirty or bad sensor. However there is a list of things that could cause that engine reduced mode. And since I can't just change the sensor, I would have to change the whole TB. I found a used one from the salvage yard for $45 which is pretty decent compared to them new.
I just wanted to avoid throwing $45 away to if it's not going to fix that engine reduced mode. It doesn't happen enough to be greatly concerned. But when it does there is a 50% chance that I am stranded. Like I said the only code it throws when engine reduced mode is the P0411 SAI. But that P0411 might be thrown as the result of the engine reduced mode. But then again I've gotten the P0411 from time to time after a few seconds of starting the car and it stall. But it always fire right up and good to go. I just clear the code. The car has never stalled beyond the 10 second startup period.
Old May 3, 2017 | 02:43 PM
exninja's Avatar
I'd bet the TB is a red herring. I'm thinking you just never noticed how noisy it is. Mine has always been very noisy on start and shutdown and works fine. That said, you can check the throttle position with any OBDII scanner. Just check if the numbers make sense.
Old May 3, 2017 | 04:24 PM
Boujii's Avatar
So I go out for lunch and bang, engine power reduced. So I hook up the scanner and got some new codes. Along with the normal P0411, I got a P0651 and C0700 P.
P0651 Sensor Reference Voltage 'B' Circuit/Open
I haven't quite found what the C0700 P is for yet. But it's not the C0700 Level control accessory inflator switch circuit high.
I found a youtube video explaining Chevy Cobalt No Crank P0411 P0651 Fix. Though I haven't reached the no crank problem yet.
It would appear the bad air pump would not supply the 5 volt which is what triggered the P0651 code. I'll have to take it off and inspect it. The guy in the video was unsuccessful at just cleaning it out and had to replace it.
I am still not so certain the cause for the P0411 SAI code. It may be a problem on it's own or caused by the bad air pump. I haven't researched yet if the Secondary Air Injection uses the same air pump.
Edit: It appears this has both separate Air Pump and Secondary Air Injection pump. Strange that I would get codes for both pumps.
Last edited by Boujii; May 3, 2017 at 04:40 PM. Reason: Does have both and Air Pump and Secondary Air Injection Pump
Old May 7, 2017 | 03:34 AM
Boujii's Avatar
So today I try to address the P0411 and P0651 codes resulting in stall and engine power reduced.
After installing a transmission in my GMC Jimmy and an Oil Change on the wife's Town and Country, I lacked the ambition to pull the primary and secondary air pumps on the cobalt.
I did look at the connector on the primary air pump and it looked fine. It seems to be a 2 wire (positive and negative) is the only thing I see electrical going to it. I am not sure where it is getting the Sensor Reference Voltage 'B' Circuit/Open from.
The secondary air pump has a 6 pin connector going to it. When I pulled the connector apart, the wiring harness connector end looked a bit wet. So I looked at the connector on the secondary air pump and it was quite damp. So I sprayed some throttle body cleaner in both connections and then cleaned the pins up. I then took a blow dryer and dried them.
The video I showed is a guy dumping water our of the primary air pump. However the secondary air pump had water in the connectors. So both of these may have water inside them.
I'll need to verify the primary air pump doesn't have another electrical connection to it besides the 2 power wires. At this point I am going to wait until something happens again. If either code comes back, I will take the pumps apart to see if there is water inside them. I am guessing these build up some condensation and just doesn't evaporate.
I'll follow up when either something happens again or I know something more definitive.
Thanks friends,
Jeff
