Placement of alcohol pump... help
Old Apr 11, 2008 | 07:44 PM
VolklSkiier's Avatar
K... I wanna put the extra tank here...
That way Ive got easy filling access...
The pump is the problem I'm having a problem finding a place for...
Is the wheel well liner stong enough to hold it... it fits behind the hedlight casing alright, Im not sure if that plastic will hold it...
Other though was mount it on the fire wall, but idk if itll be to hot back there? will that even matter?
Or try to find a place on the otherside of the bay somewhere?
Out of curiosity how far will the engine rock, like max (aprox)?
anyone?
bump?
Bumpppp?
Last edited by VolklSkiier; Apr 11, 2008 at 07:44 PM. Reason: Automerged Doublepost
Old Apr 11, 2008 | 10:54 PM
bluecobaltss06's Avatar
When I did the install I moved the horn and used the studs that are already there and used self tapping screws to put the rest in. It sits hidden underneath the d/s h'l. then i mounted the horn on that huge ground screw thats there. I used those two studs next to your tank to create a bracket that held the tank in place
Old Apr 13, 2008 | 09:03 PM
Did you have any pics?
eazyasone23
How to Guide
May 13, 2013 02:29 PM
blueta
How to Guide
Jul 30, 2009 07:26 PM
blueta
How to Guide
Apr 13, 2007 09:44 AM
