Premium Fuel
Old Nov 22, 2007 | 07:09 PM
Mark McCullin's Avatar
Premium Fuel
I've just picked up a Cobalt SS/SC. Should I be using premium fuel?
Old Nov 22, 2007 | 07:13 PM
HickOverLOrd's Avatar
Yes.
Old Nov 22, 2007 | 07:27 PM
Originally Posted by HickOverLOrd
Yes.
Thanks
Old Nov 22, 2007 | 07:45 PM
BlackSSNick's Avatar
now this thread gets right to the point
Old Nov 23, 2007 | 09:25 AM
kenhebe's Avatar
Any forced induction vehicle requires the usage of premium fuel. Yes it will run with a lower grade, but it runs poorly. I honestly don't even know how much gas costs becuase I have to pull the trigger on 93 regardles of price. Besides, is an extra 20 cents a gallon really going to break your back?
Old Nov 23, 2007 | 10:09 AM
Regular gas is up over $1.05 Canadian
Old Nov 23, 2007 | 10:11 AM
kenhebe's Avatar
I think it is like $3.15 here, but I am not too reliable a source on that.
Old Nov 23, 2007 | 10:22 AM
ouch, That's rough
Old Nov 23, 2007 | 10:41 AM
stlurbanpunk's Avatar
Originally Posted by Mark McCullin
ouch, That's rough
320 here for premium, i thought that was the least expensive across the us.
Old Nov 23, 2007 | 12:33 PM
an0malous's Avatar
thats not bad at all.
if you convert it over, canadians are paying well over 4 US dollars a gallon.
Old Nov 23, 2007 | 12:35 PM
lOwBaLt's Avatar
premium fuel is good for anycar imo. Helps lower emissions, cleans ur engine (not sure), and you might get better mileage.
Old Nov 23, 2007 | 12:38 PM
07cobaltss's Avatar
Higher the octane the harder is is to burn, this is why it is good for higher compression cars, and it also helps with knock. and it does have more cleaning additives to it.
Old Nov 23, 2007 | 12:39 PM
an0malous's Avatar
doesnt clean your engine, and you will only get better mileage, power, or emissions, if your car is tuned for it.
Fortunately the ss/sc is, so its most definately best to put premium in it
Old Nov 23, 2007 | 12:41 PM
D4u2s0t's Avatar
not true at all. if your car is not designed or tuned to run on premium, you'll get worse gas mileage. it doesn't help clean your engine at all either, that's an old myth. it also doesn't have lower emissions.
you should use what your car was designed for. using too high OR too low octane is not a good idea. all you're doing is wasting your money and hurting performance if your octane is too high for the car.
damn, it, beat me to it!
Old Nov 24, 2007 | 06:52 PM
YSUsteven's Avatar
Read your owners manual, I think it says that you can but you will have power loss, and why would you want that with an SS.
It is also known that Knock destroys engines. Knock is caused by lower octane fuel.
Old Nov 24, 2007 | 06:55 PM
flathead0's Avatar
$3.72 a galllon bend over and take it
Old Nov 24, 2007 | 06:56 PM
bigrroberto's Avatar
will it benefit the 2.4l to run premium?
I heard premium was good to run in all vehicals because its easier on the engine, less wear and tear kind of idea. Don't know if it's true or not, but that's just what I heard
Old Nov 24, 2007 | 07:02 PM
caustin8503's Avatar
no bigrroberto unless then 2.4 was designed for it and i dont think it is
Old Nov 24, 2007 | 07:04 PM
interesting.
Old Nov 25, 2007 | 09:25 AM
CSM Huber's Avatar
Cool 2.4 LE5 takes 91 octane!
Originally Posted by bigrroberto
interesting.
My owners manual shows 91 octane as the fuel to use for the 2.4L NA LE5 Engine.... 89 octane will work with reduced performance. Local Sam's Club sells 93 octane for $3.15.9 then I get five percent back with my "card" so it runs $3 a gallon. With 93 octane, my 2007 Cobalt SS is getting 30 MPG highway and averaging 23 - 24 MPG city/rural (10 - 15 mile round trips).
Old Nov 25, 2007 | 09:32 AM
devon9832's Avatar
well it all comes down too simply this....WE NEED THE GAS, so they figure we don't care about the price...just bend over and take it with no lube..cuz we are going to give you a good butt huggin
Old Nov 25, 2007 | 11:49 AM
an0malous's Avatar
should be puttin premium in her rob.
no ifs ands or buts.
Old Nov 25, 2007 | 11:53 AM
D4u2s0t's Avatar
guess you didn't read my post 2 above yours
Old Nov 25, 2007 | 10:05 PM
Vetteman-sssc's Avatar
Yes ,91-93 oct premium fuel only in the SS/SC
Old Nov 25, 2007 | 10:24 PM
pdub's Avatar
Make sure you fill up at TOP TIER stations. It is in the manual.
