View Poll Results: Problems with your Cobalt?
I have some problems with my balt
12
48.00%
I don’t have problems with my balt
28.00%
I have lots of problems with my balt
16.00%
Man sorry you just have bad luck
8.00%
Voters: 25. You may not vote on this poll
Old Dec 27, 2007 | 02:08 AM
Slowbalt SS05's Avatar
Question Problems with your Cobalt?
How many of you have had problem with you SS\SC or your 2.2, 2.4 balts, or is it just me that has bad luck. Post what had happened to your car, and how many times you have had problems small or big, just wants to make sure if it’s just my car or do I just have bad luck.
Old Dec 27, 2007 | 02:27 AM
Raven SS's Avatar
u cry too much david lol..try close to 7grand..
Old Dec 27, 2007 | 02:30 AM
Super_SS's Avatar
wow, what a great thread. okay
i had CEL lights to the max... went to the dealer 6 times i believe for the same problem...
Clutch fcked up
Tranny went BOOM!!!!!
Runnin way to lean*dont no how*
Pulley tensior or w.e
Power steeering pump
thats a few that happen recent
Old Dec 27, 2007 | 02:38 AM
HAHAHA Man I love this car but man I’ve only had it for 6 months and this car has seen the mechanics shop or the dealer, ever since I got it.
Old Dec 27, 2007 | 02:40 AM
Raven SS's Avatar
ive had it since september and u know what mines going thru
Old Dec 27, 2007 | 02:53 AM
Man your car has the flue right now a bad flue
Old Dec 27, 2007 | 02:55 AM
Raven SS's Avatar
lol..
Old Dec 27, 2007 | 03:21 AM
deuce's Avatar
congrats to raven 2000 posts!
Old Dec 27, 2007 | 03:28 AM
Raven SS's Avatar
lol thanks
Old Dec 27, 2007 | 03:37 AM
rick1217's Avatar
motor mount, then just small stuff, top of shifter knob came off(crazy glued it back on), paint on some of the dash trim is starting to wear off
(dont know what to do), flange after the cat on exhaust was leaking(but i fixed it), stock cd doesnt play cds sometimes, sometimes cd's get stuck and you have to use another cd to get it out....
Other than that no problems.... stock perillis only lasted 4k, My other tires(cheap) I can get over 20-30k
Old Dec 27, 2007 | 03:39 AM
Raven SS's Avatar
the trim is covered on the bumper to bumper warranty
Old Dec 27, 2007 | 03:48 AM
Aleckor's Avatar
Reverse Shift Lever broke off.
Engine randomly stalled.
Reverse Shift Lever broke off again.
Two fronts bald after 3600 miles.
Dome Light stopped working.
Radio stopped working. (LED Display refused to come on, or scrambled, speakers fade in and out)
Driver's side door installed improperly from factory.
Passenger door window crank installed improperly - rattled VERY loud.
New radio stopped working. (Wiring harness likely faulty)
Two NEW fronts bald after 7000 miles.
Two rears bald after 9000 miles.
Did I mention that the reverse release shift lever broke again?
-Aleckor
P.S. All that crap was covered under warranty, except the two rears, and the second set of fronts. (They gave me two free new fronts because they had never seen them wear out so quickly before)
Old Dec 27, 2007 | 08:43 AM
Co|3aLt $$'s Avatar
I have bunch of stuff wrong with the car, however the dealerships been pretty good to me with it. Also, when I mess with the car they don't say anything lol, which is always a plus.
Old Dec 27, 2007 | 09:17 AM
speed_demon05's Avatar
I have only had to take my car to the dealer once in a year. My coolant sensor went bad and while it was there they noticed that the motor mounts had come loose so they fixed that too. And the top of my shifter came off to ( just glued it back on) But thats it for mine.
Old Dec 27, 2007 | 09:23 AM
Acer00789's Avatar
Everyone is going to have at least one problem with there car. Like me, the yellow plastic piece infront of the blinker light inside the headlite just fell out. I didnt hit anything and its not broken, its just laying there inside my light. Other than that I go thru alot of tires, but thats not my balts fault.
Old Dec 27, 2007 | 09:34 AM
R&C_rallySS's Avatar
I only had one problem with my cobalt in nearly over a year. The clutch. So I just stuck in the most expensive best clutch upgrade I could find. It fixed the problem and man does the Exedy Clutch/flywhee/pressure plate work awesome.
Old Dec 28, 2007 | 09:30 AM
phuwalt's Avatar
Gotta love problems -
Steering wheel audio controls fail to work sometimes
Drivers side door installed improperly - it snaps near the front wheel when i open or close it.
(2.4 auto) When putting the car in park - sometimes it wont let the key go.. like it wont recognize that its in park unless i really jiggle the shifter
Really bad rattling under the hood, mostly when breaking, but happens when not breaking sometimes too. Sounds like the headlight is going to fall out or something
Door trim paint is rubbing off badly
yeah - my car has been in the shop since 8am yesterday and they still havent called me today. Pretty soon my ass is going to need a rental car.
Old Dec 28, 2007 | 07:30 PM
dam im not the only one
Old Dec 28, 2007 | 07:38 PM
Altiery54's Avatar
had mine for 9 months and not 1 problem that i am aware of so far. knock on wood
Old Dec 28, 2007 | 07:41 PM
OneSlowGto's Avatar
I had a **** load of problems with my balt.... I would blame some of the on the mods though.
Old Dec 28, 2007 | 08:03 PM
ptrblkz24's Avatar
Had mine for 1.5 years,not 1 problem yet.*knocks on wood*
Old Dec 29, 2007 | 12:16 AM
Mr_Slobalt's Avatar
misaligned hood caused the corner to fold- straightened and repainted
sunroof track broke causing creak and pop- replaced sunroof module
d/s inside door weatherstripping came loose- replaced
various rattles from glove box, to rear seat, to d/s door panel- loose window regulator
slipping clutch which might be replaced soon
loose d/s and p/s cv shafts- lubed splines and re-tightened
popping in steering- lubed steering shaft
loud popping in d/s seat- still unsure
lubed sticking door handles
creaking from around clutch pedal when applied- lubed around clutch interlock switch
I think I may have a bad tire too.....
I didn't realize how many I've had so far under 12k miles. Wow. I've also replaced the wiper blades and a corner bulb since buying it. Free under warranty FTW!
Old Dec 29, 2007 | 12:31 AM
TheCaptain's Avatar
17 000 Kms. 1.3 years old. (Sept 06)
2007 SS SuperCharged - single issue - drivers headlight came with orange reflector. 07 SS' aren't supposed to. *Problem resolved under warranty, new headlight casing.
Doesn't anybody realize when buying a first or second model year vehicle, There ARE ISSUES AND BUGS to work out yet!? Nobody ever heard the term, "don't buy a first or second model year vehicle?"
I figure its the price you pay for having something before everyone else i guess.
Old Dec 29, 2007 | 12:36 AM
o3nisoaso3's Avatar
I have CELs all the time but that is just normal from what i hear. other than that it runs like a champ
Old Dec 29, 2007 | 12:37 AM
Mr_Slobalt's Avatar
I'm not complaining at all. It's a great car. Just the little bugs like you said.
I do all the work, so, I get the money and the satisfaction of working on my car at work. lol
