Question about Adding Fuel / Air Mixture Gauge
Old Oct 26, 2009 | 12:25 PM
insylem's Avatar
Question Question about Adding Fuel / Air Mixture Gauge
Not sure if this is the best spot for this message.
When I baught my Cobalt, I traded in my old Dodge Shadow. It needed an O2 Sensor,
and so I still have the new unused O2 Sensor for my shadow? Is it possible/ practical
to do a mod to install it in my Cobalt exhaust system so that it runs ONLY a FUel / Air mixture gauge?
I'm guessing I"ll need to make some sort of Voltage regulor to power it, No problem 1 Amp and below regulators are a sinch to make for 1 - 18 VDC thanks to the LM317 chip.
But since id be useing a Shadow's O2 sensor, im guessing id need a Shadow's gauge? Designed to read off of that sensors...
So where should/ could I put it? The sensor that is?
Or would this not really work so well?
-Jonathan
Old Oct 26, 2009 | 01:48 PM
Cobaltsky05's Avatar
you could but you could also tap into your stock wiring to run an AFR gauge, but to run a WIDEBAND you will need to get a different sensor all together. They are five wire, vs stock o2 sensors are four wire. Some cars come stock with a five wire if you wanted to do it cheap though I am sure you could find an EVO, WRX or some other car that has a five wire and do exactly this.
Old Oct 26, 2009 | 02:04 PM
ColeJJones's Avatar
Bannned
just get a new wideband
Old Oct 29, 2012 | 01:35 PM
insylem's Avatar
I did,
I got the Aeroforce Wideband kit hooked to my interceptor.
Old Oct 29, 2012 | 02:09 PM
Vander Nars's Avatar
lol why are you necroing all ur post from 09?
Old Oct 30, 2012 | 01:06 AM
insylem's Avatar
To celebrate holloween this week.
Old Oct 30, 2012 | 02:41 AM
Haven07's Avatar
Halloween
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
