A question about dynos?????
Old Oct 8, 2006 | 05:18 PM
g5mike's Avatar
Im set to get a tune and dyno once the JBP cams are on my car> My question is the one dyno that I know for sure can hp tune my car is a mustang dyno and the other one is a dyno jet but dont know yet if they use HP tuners, All I want to know is what type of dyno will give me the most accurate results, thanks to all for responding????
Old Oct 8, 2006 | 05:21 PM
Orlandoech's Avatar
Most ppl like Dynojets better cuz they give higher numbers, but they both are accurate.
Mustang dyno will give the same numbers with WCF = Weather Correction Factor
Old Oct 8, 2006 | 05:23 PM
g5mike's Avatar
Thanks, so if I go to the mustang dyno, the owner will adjust this accordingly?
Old Oct 8, 2006 | 05:29 PM
cvenom2122's Avatar
Thumbs up
you will see lower numbers on the mustang dyno but as long as you continue to stay on the same dyno youll see a big difference in numbers from stock to modded
Old Oct 8, 2006 | 05:31 PM
g5mike's Avatar
Thanks, I wont be able to do a pre run, for the cams are off my car already,just gonna have to go off of someone elses 2.4 with the same mods
Old Oct 8, 2006 | 06:28 PM
Orlandoech's Avatar
Mustang dyno's give lower numbers but when they give you the corrected numbers they will be close to a Dynojet numbers
Old Oct 8, 2006 | 07:00 PM
g5mike's Avatar
ok1 this helps alot, because the guy with the mustang dyno is the same guy who does hp tuners
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
maliki778
Oct 1, 2015 07:39 PM
Extremespeed
Sep 29, 2015 04:34 AM
Sep 27, 2015 08:53 PM
