Question about Interceptor Gauges.
Old Mar 1, 2010 | 12:33 PM
insylem's Avatar
"CMD A/F" is one of the options for paramaters to display, this is not listed from what I can find in the instructions (Firmware v2.7) It shows about 14.7 or so and yes it does change sometimes while I drive, but not much. What is "CMD A/F" ? I'm guessing Command Air Fuel, but I don't see a reading for the current A/F
Also, the "Gallons Left" for fuel says Gallons,
however, I have a 13 Gallon tank, and i just filled up and it says 50.6,
this is more consistant with Liters rather then gallons (13.3 Gal = 50.6 Liters)
And yes i have seen this number change as well.
Is there a way to convert the Liters to Gallons?
Are these supported by our vehicals? I noticed that the list of paramaters in the instructions differ from those selectable on the gauge.
Old Mar 1, 2010 | 12:46 PM
CudaJoe's Avatar
CMD A/F is in fact Command A/F. It is the reading the ECU is telling the engine to target. There should be an A/F reading as well. I have it. The A/F ratio tells you is the result from the command. hope this helps.
Old Mar 1, 2010 | 01:00 PM
insylem's Avatar
Question
Ok, I couldn't find a AF Ration that is the result. But thanks Any ideas how to convert the 50 liters to 13 gallons?
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
