Questions about 3 gauges on driver piller
Hey,
Im having trouble with the three gauges on my driver side piller. Right now it has a oil pressure gauge, an air fuel ratio gauge, and a boost gauge. The Air flow ratio gauge and the boost gauge aren't working right, and need to be replaced. I think i am going to have to replace all three even though the oil pressure gauge works fine, becasue i want them all to match perfectly (not look different from each other at all). I found the autometer part number for the oil pressure gauge (4727) but the boost and air fuel ratio gauges dont show the part number on them. Does anyone have a clue what the part number is for them.
Also, does it matter if i use the same exact gauges that are currently installed (basically cobalt SS specific) or will any gauge that is 2 1/16 size work?
Last, will they come ready to go after hooking them up, or will i need to take it to a place and get them tuned to my car?
thanks for the help!!
ya look at the one in the problems thread. i put it in the wrong forum so tried to changed it, and now i dont know how to delete the old ones i put it in. sry
so I googled "autometer 4727", and came up with autometer carbon fiber series oil psi gauge--that what you have?
so google "autometer carbon fiber boost " and "autometer carbon fiber afr" I'd bet you a paycheck you can figure out from there what part #'s you need.
definitely NOT Cobalt specific.
