Quick I Need Help!!!
Old Nov 27, 2006 | 10:19 AM
amomentsnotice's Avatar
so i went to turn my car on and i dont know if its some kinda safety feature something but it wont let me turn the key!!!!!
my battery is ok, i tried turning the steering wheel, took the ebrake off, put it in and out of gear but i cant get my car to turn on!!
does anybody know a way around this or what it is??
thanks so much!
Old Nov 27, 2006 | 10:33 AM
bc3tech's Avatar
thanks so much!
Since these cars are really close to the Ion i'll let you know what my experience was.
As weather got colder when I was living in wisconsin I noticed a few things w/ the ignition. Sometimes I couldn't turn the key and other times I could but even when i got to the 'start' spot the engine wouldn't start up. It wasn't the characteristic "clicking" when the battery goes out or anything, but just nothing.
Turns out there was a TSB on the Ignition module of the Ion's (I have a 2004) where the grease they used to lubricate the ignition area behind the key would get very gummy and not allow the contacts to come together in colder weather. I took it in, showed them the TSB, and it was all fixed under warranty w/ no more issues.
You may want to check on the same sort of issue for your car.
Old Nov 27, 2006 | 12:36 PM
Badmunky's Avatar
I had the same problem with a malabu and it turned out to be a bad ignition.
Later
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
