Quick question...cooltant temp
Old Feb 25, 2009 | 09:51 AM
Preston's Avatar
Well every since i have turbo'd my car
my fans didn't work..so i hooked them directly up to power so they would work.
and now even with the fans on the cooltant still goes way up in temp (210-220) then i would shut the car off at 223ish
but i have a cooltant temp sensor on hold at autozone. (i think thats what it is called)
is this what i need to buy? or what should i look at getting..i've been suggested to get this..by 2 people..and one of which worked at a dealership.
Just looking for suggestions from others..of what may be the problem..
Also i have thrown all these codes..most whati think deal with my Oxygen sensors being out
P0030
P0036
P0053
P0054
P0134
P0135
P0141
idk what any of the codes are if someone wants to look them up for me
thanks for the help
Old Feb 25, 2009 | 09:53 AM
DebadgedBALT77's Avatar
theres a list of trouble codes somewhere on here.
and id go with the temp senor myself as well. not to sure, but id bet that may have something to do with it.
btw, hows the turbo? likeing it so far?
Old Feb 25, 2009 | 09:59 AM
JTob's Avatar
Ok quick question. You did retune the ECU after installing the turbo right.
Old Feb 25, 2009 | 10:13 AM
koch1ar's Avatar
hopefully
Old Feb 25, 2009 | 11:21 AM
rnjmur's Avatar
P0030
P0036
P0053
P0054
P0134
P0135
P0141
thanks for the help
If you are getting a coolant temp reading on the DIC then I don't think the coolant temp sensor is bad. When the car was tuned for turbo did they mess with the fan settings? Typically the fans don't even kick on till 223 F. Also, if you wired the fans to be on all the time you can cause less air to be pushed through the radiator when you are moving which may explain why the temps rise.
Old Feb 25, 2009 | 12:59 PM
Preston's Avatar
yeah i did a retune with vince.
and he the fans to supposed to be turning on at 195 degrees...but nothing
this what i need?
http://www.autozone.com/selectedZip,.../selectZip.htm
THIS IS WHAT AUTOZONE IS HAVING ME GET!! LET ME KNOW IF I NEED THIS!!
http://www.car-stuff.com/carparts/ch...698197469.html
OR TELL ME WHAT I NEED! I need my car driveable by the weekend..i already have kept the tuner longer than 2 weeks, with vince knowing of course..but still.
Old Feb 25, 2009 | 01:31 PM
Tomtwtwtw's Avatar
I just have to throw this out there -
Since you wired the fans yourself, did you make sure they're spinning in the right direction when on? One little switch and you've got fans blowing engine bay air back through the radiator.
Old Feb 25, 2009 | 01:39 PM
Preston's Avatar
yeah i put my hand down there and can feel the air blowing hard on the motor...
i searched and found that i MAY have a "air bubble" in my cooltant system
they said to ( on this site) to take off the coolant cap, and let the car idle for a few minutes..and if this doesn't work
then its the temp sensor i guess
Old Feb 25, 2009 | 04:39 PM
rnjmur's Avatar
I think the problem maybe in the fan setting of the PCM. Again, if you can see the coolant temp reading on the DIC then I don't think the coolant temp sensor is bad.
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
