Redline not at 6500...wtf?
Old Jan 13, 2006 | 11:27 AM
freakaccident's Avatar
I kept hitting my rev limiter on shifts and figured out that my rev limiter kicks in at 6250 and NOT 6500. WTF is this all about?
Old Jan 13, 2006 | 11:34 AM
06black's Avatar
thats were its set at
Old Jan 13, 2006 | 11:49 AM
Adirondack_Cobalt's Avatar
You are probably hitting really close to 6500RPM, but the gages in these cars are SLOW... they a bit behind the actual engine speed. I had a Daytona that was the same way.
Besides, why do you want to rev to 6500RPM in the first place... the car is ready for another gear by 6000RPM... shift it, boy, shift it!
Scott
Old Jan 13, 2006 | 12:04 PM
JamesBrown's Avatar
Scott
The car is still making power up to redline.
Old Jan 13, 2006 | 12:10 PM
Exactly.
Old Jan 13, 2006 | 12:21 PM
97cavie24ls's Avatar
the stock tach is slower than molasses
and the motor needs a 7K redline
Old Jan 13, 2006 | 12:37 PM
Thanks for the explanation guys.
I think the motor needs a 7k redline too AND a longer first gear.
Old Jan 13, 2006 | 12:51 PM
BLKSS's Avatar
I bounce the rev limiter sometimes. Funny, feels like im going faster when I hit it.
Old Jan 13, 2006 | 01:04 PM
memphisr24's Avatar
LOL when I hit it, it seems as if the car falls flat on its ass.
Old Jan 13, 2006 | 01:14 PM
pclear9061's Avatar
actually the redline is set at 6450 not 6500
Old Jan 13, 2006 | 01:18 PM
pclear9061's Avatar
Also depending what gear your in the tack is alittle behind in the first, second and sometimes third. so when ur in first and second by the time the engine tacks out at 6450 and the tack says 6200/6300 its actually at 6450. when you get into gears 3/4/5 thats when you see a more accurate reading of the rpms, unless you are in gears 1/2 and taking off fairly slowly and keeping it at a slow and steady pace then the rpms are ALOT more accurate.
Old Jan 13, 2006 | 01:20 PM
1stbluSS's Avatar
I would prefer a 7250 redline. This car would be ridiculous with that as a redline.
Old Jan 13, 2006 | 01:23 PM
pclear9061's Avatar
yeah no kidding but at 7250 your gonna mostlikely replace the internal springs b/c if i remember correctly they will not last very long at that high of an rpm
Old Jan 13, 2006 | 04:13 PM
Better yet, what about the timing chain. Can that thing handle high RPMs? You might be able to change the springs but we don't have a timing belt. Im not sure what happens with timing chains at high rpms.
Old Jan 13, 2006 | 04:17 PM
pclear9061's Avatar
im not quite sure either
Old Jan 13, 2006 | 04:52 PM
Mercury's Avatar
I agree!
Old Jan 13, 2006 | 05:02 PM
johnkb8's Avatar
this is true, but i would like the 7200 or so also!!
Old Jan 13, 2006 | 05:06 PM
the grand am cup cobalts , have a 7000 redline , and 18psi
and the motor is the same as in your ss/sc's
and not 1 motor failure all last season
Old Jan 13, 2006 | 05:13 PM
BullDog71ss's Avatar
Scott
That's funny, mine feels smooth as silk up to redline. Mine screams "GIVE ME MORE RPMS YOU *****!" but fuel cutoff gets in the way of that. This engine should be set at 7,000.
Old Jan 13, 2006 | 06:36 PM
that's funny, as I approach the rev limiter my engine is screaming "ABUSE VOIDS WARRANTY, *****!" at me.
Scott
Old Jan 13, 2006 | 08:51 PM
Scott
Not if they dont find out.
Old Jan 14, 2006 | 02:31 AM
mrbelvedere's Avatar
the timing chain will handle well beyond our redline and all they need to do is plug in to your car and then they know how you are driving it
mrb
Old Jan 14, 2006 | 11:18 AM
Jsamps07's Avatar
I shift mine at like 5800 or 6000 RPMs. I can tell a difference from shifting there and 6500 because it seems like mine does lose power if I shift at 6500 where-as i dont as 5800. 1st gear is a turd in this car though.
Old Jan 14, 2006 | 11:22 AM
Brian MP5T's Avatar
What's a rev limiter
Old Jan 14, 2006 | 03:27 PM
dirtySSout's Avatar
mine does the same at 6300 rpm. i guess tach is just slow
