remote start question
Old Feb 10, 2007 | 02:44 PM
VeNoM0713's Avatar
i just got the Compustar Pro P2W9000FMR installed and this question is to whomever has a compustar remote start. where do they put the module? i want to change it to run to 25 mins from 15 mins. i really dont want to drive all the way back there again when its just a switch. let me know.
Old Feb 10, 2007 | 02:49 PM
FinalBreath's Avatar
Just a question but where did you get it and how much was it? I'm looking to get one installed on my car. pm me please
Old Feb 10, 2007 | 04:32 PM
VeNoM0713's Avatar
you need to go to compustar.com and email them and ask what dealers have them in your area. and it cost me 400 bucks for just the starter.for some reason they still gave me the alarm and i told them i didnt want the alarm or keyless entry.
Old Feb 10, 2007 | 05:26 PM
Halfcent's Avatar
I'm old school
Call the shop that did you installation and ask the installer. It could easily vary from shop to shop.
Old Feb 10, 2007 | 05:30 PM
wdsoccer's Avatar
i am gonna get a compustar remote starter as soon as i get enough money. im gonna get this model Compustar Pro P2W9000FMR. check it out. its pretty badass
Old Feb 10, 2007 | 06:12 PM
VeNoM0713's Avatar
thats the one i got lol... but halfcent, i have an appt for them to switch the run time for me but i dont want to drive that far again just so they can flip a switch.i already looked it up and its just an on/off switch on the module. my question is that i have no idea where they put it. under the dash maybe? no clue.if anyone knows help me out.
Old Feb 10, 2007 | 06:34 PM
jester's Avatar
They put mine behind the little drawer you pull out thats to the left by the trunk release. They pushed the sides of it together and got it to come off of there somehow, probably easier to just take the panels off. But anyways im pretty sure thats where it is.
Old Feb 11, 2007 | 12:00 AM
redSSBalt's Avatar
Modules for alarms and or remote starts, are always buried up in the dash where ever they fit. If you lay on your back on your floor, then look up in the dash with a light so you can see. You should be able to spot the brain for it. I know this from being an ex installer for years. I've installed my share of Compustar's as well. It was a good choice you made.
Old Feb 11, 2007 | 02:44 PM
PolishPauL's Avatar
So can you put this on a manual. I know Chevy doesnt offer it for them.
What you guys think of the best buy one. I saw it one time in the weekly add for like 200 wit installation.
Old Feb 11, 2007 | 02:53 PM
sethallen's Avatar
i have yet to find a place that will install a remote start in a manual trans. car
for obvious reasons
i know for a fact that best buy wont
Old Feb 11, 2007 | 07:12 PM
PolishPauL's Avatar
for obvious reasons
Why wont they do it?
Old Feb 11, 2007 | 07:15 PM
06 pursuit gt's Avatar
just under the steering wheel there is a panel that entirely pops right out. thats where they put mine mine is "Command Start"
for obvious reasons
thats untrue cause i got a 5 speed pursuit they installed it on mine although it took them 5 hrs... what would these obvious reasons be?
Old Feb 11, 2007 | 08:26 PM
redSSBalt's Avatar
for obvious reasons
It is 100% legal to have a remote start in a manual transmission car as long as it's the correct unit. You can't just take any old remote start and put it in. It has to be the correct style to be legal. So with that said, the only obvious reason as you are saying would be they don't have it or don't know how to do it!!
Old Feb 11, 2007 | 08:35 PM
CinciSS07's Avatar
why is it illegal to have some starters in a manual?
Old Feb 11, 2007 | 10:36 PM
PolishPauL's Avatar
I dont understand whats so different. Does it have to do wit how you put it in neutral, not park?
Old Feb 12, 2007 | 01:53 PM
akJBody's Avatar
I have the same unit. It seems to work a lot better than some of their older units. Manuals require the car to be put in reservation mode in order to actually use the remote start function. Only certain model remote starts are designed for manuals, therefore you have to get one that is. This is how reservation mode works on manuals....directly from the compustar book...
To use the remote-start function on a manual transmission vehicle, you must first set Reservation Mode. Reservation mode sets the vehicle up
to safely start the next time you use the remote-start. To set Reservation Mode, follow these steps:
1. Completely stop the vehicle and put it in NEUTRAL.
2. Set the emergency brake and remove your foot from the foot brake.
3. A few seconds later you should hear a “click”.
4. Turn the key off and remove it from the ignition. The vehicle will stay running.
5. Exit the vehicle and close the door.
6. The vehicle will shut off, the system will arm, and the doors will lock.
Reservation Mode has now been set. The following actions will cancel Reservation Mode; opening the hood, doors, or trunk, turning on the
ignition, releasing the emergency brake, turning on the ignition, or triggering the alarm. If reservation mode is cancelled, you will need to get in
the vehicle and repeat the setup process.
Most of which is true. I can still get in my trunk and the car remains in reservation mode. My alarm can be triggered and still will stay in reservation mode. The only way mine leaves reservation mode, is if the doors are opened. The remote has a little key showing if the car is in reservation mode and able to be started. Otherwise, no key...no start. It is an awesome unit.
Old Feb 12, 2007 | 02:07 PM
slvrcobaltscss's Avatar
i work at best buy and i know they legally cannot install remote start on a manual transmission. this is because in the state of PA you cannot legally park your car in neutral which you would have to do with remote start. it sounds strange, but it is in fact a law that you must park your car in gear at all times. they don't go crazy with enforcing it, but because of that installation shops can't do it...now if you know them well enough (ie if you work with them) they'll do it for you but legally they can't...i know this is all true for PA not sure of other states
Old Feb 12, 2007 | 05:39 PM
redSSBalt's Avatar
Then come over the border to Ohio and get one installed.
Old Feb 12, 2007 | 08:02 PM
sethallen's Avatar
best buy wouldn't install one in my car because of liability reasons. theyre example was if the vehicle is left in gear, then started via remote, the vehicle will obviously smash into whatever is in front of/behind it
Old Feb 12, 2007 | 11:46 PM
you can install a mercury switch in the car, that way if you leave it in gear, use the remote start, the car will lurch forward a few inches but the mercury switch will then disable the clutch...not sure entirely how it works, but it does...like i said my store will do it for people they know, so pretty much all the employees with manual cars have the remote start and the mercury switch really works, the car will only move a few inches
Old Feb 13, 2007 | 06:08 PM
redSSBalt's Avatar
Tell them they need to get their heads out of their A**!! There are special remote starts that are made for manual transmissions!!
Old Feb 14, 2007 | 09:09 PM
how r they liable if ur stupid enough to leave it in first its totally the owners fault
Old Feb 14, 2007 | 09:12 PM
sethallen's Avatar
its possible to knock it into gear by accident, or have a 3 yr old that likes to play with the gear shifter
Old Feb 14, 2007 | 11:19 PM
mkulrey13's Avatar
thats why you put a starter MADE for a manual... if anything triggers that someones in the car the mode is turned off and cannot be started(moving shifter, opening doors trunk hood)... guess everyone miss that part of the thread!
Old Feb 15, 2007 | 04:38 PM
doesn't really have to do with them having their heads up their ass...best buy installs products that best buy sells...do some research: www.bestbuy.com now tell me where you see a remote start kit designed for manual transmissions...look at the company's reasoning before you start bashing everyone under their roof please
