Remote starter on manual SS
Old Feb 22, 2014 | 02:53 PM
  #51
sLAsh's Avatar
Remote starts are very dangerous. All someone would have to do run themselves over with my compustar is:
Roll down window; put car in neutral; pull handbrake; release clutch; open and close Door without getting out of car; wait for car to shut off and lock; crawl out window; go stand in front of car and press remote start.
As you can see this could easily happen if one was not paying attention when getting out of the car.
Old Feb 22, 2014 | 10:58 PM
  #52
StevoElSupremo's Avatar
I wish my car had remote start stupid manual transmission
Old Feb 23, 2014 | 09:12 AM
  #53
MaxDugas's Avatar
In my case, as soon as the key is not in the car, my compustar (with alarm) will shut the car if he feels that the car is moving.
Old Feb 23, 2014 | 10:05 AM
  #54
EmperorJJ1's Avatar
pretty sure he was jk... i highly doubt someone crawling out of their window classifies as easy
Old Feb 24, 2014 | 12:14 AM
  #55
Pinky Demon's Avatar
I'm going to look into getting one for my car. I like the idea of giving the car a little time to warm up on a cold morning instead of getting in it and immediately driving off.
Old Feb 24, 2014 | 02:39 AM
  #56
gloomy04's Avatar
I had one. Bad idea. Maybe if it had the safety switch to keep it from cranking in gear which mine didnt. Mechanic wrecked my front bumper. Still has to be fixed. I just had the whole system pulled off my car 2 days ago. It was bypassed so long I can't remember if it was supposed to crank in neutral without pressing clutch or not. For the record it doesn't
Old Feb 24, 2014 | 08:26 AM
  #57
MaxDugas's Avatar
That's because he wasn't installed properly, normaly a remote starter is not suppose to crank in gear, it will do nothing.
Old Feb 24, 2014 | 11:49 PM
  #58
alerosaint's Avatar
lmao
You can get it with a manual tranny
Mines won't go in remote start mode unless I take it out of gear, hand brakes are up.If it remotes start in gear it would be an intentional action cause it would have to go back in gear after engine shutdown, which the engine don't shutdown till the alarm is armed which when you open the door after arming without remote starting cancels the remote start operation so it is,pretty hard to eff it up
Old Feb 25, 2014 | 01:45 AM
  #59
serega12's Avatar
sooo... how do you wire the clutch bypass? Nobody has answered that one straight yet. And I hope Alerosaint will get back to me with the contact info for his installer, I might drive up north this Friday and have one installed there...
Old Feb 25, 2014 | 08:59 AM
  #60
alerosaint's Avatar
I PM'd you back. Its best to call and schedule and hopefully they have a friday sllot. Cause I made a wasted drive there when someone told me to just come in and the actual installer was like its best to to talk to an installer cause they are busy. Ill go get the info for you now
Old Mar 1, 2014 | 01:49 AM
  #61
serega12's Avatar
Found an installer in Wilsonville, Oregon Fry's Electronics. Their lead installer put it in, said it was one of the most difficult installs in years.. Clutch bypass setup was pretty tough to test and wire up, then there's GM key immobilizer that requires another relay setup. That's on top of the 5704 Clifford and DBALL2... And they threw in a T530 window control module for just a price of installing it ($80). So for me it was 699 for the alarm, DBALL2, relays and install.. All said and done, $779 out the door with parts and labor, lifetime warranty on labor through Fry's and lifetime warranty on parts through DEI.
The alarm is up and running. Remote start works well. There is a little glitch though..
When you set the manual remote sequence for the first time, it shuts off normally. Then, when you try to remote start for the first time after that, it seems to think it's getting hot wired or something and does a two second long annoying factory honk and the security light starts blinking but it starts normally. If I shut it off and remote start without getting into it, there is no more annoying two second "I'm getting broken into" honk, but the blinking light is still there. And it doesn't go away unless I shut it off and start it with the key.But then while starting it with the key takes away the blinking light, it also resets the factory security and now the first remote start is with the loud annoying factory horn honk... Either way, I talked to the lead installer that put it in and he is looking into it tomorrow at work. Hopefully he finds the solution. He sounds pretty confident and was able to wire up the clutch bypass and immobilizer key bypass (which could be a part of the issue). He should be able to get it resolved, hopefully tomorrow...
Old Mar 2, 2014 | 01:56 AM
  #62
serega12's Avatar
Glitch worked out. Car Toys spliced into the wrong wire by the ignition switch and the Fry's electronics installer hooked into it. That's what caused the horn and the light. Literally took him 15 minutes to fix the issue. Now it works flawless.
Old Mar 2, 2014 | 08:33 AM
  #63
BlackielawlessSS's Avatar
I wish my car had remote start today. Zomg it is cold.
Old Mar 2, 2014 | 08:49 AM
  #64
KoriCobalt's Avatar
Been 7 months now since I've had my viper aftermarket alarm/remote starter. Been through some issues but much was to blame on the defected remoter starter module. Ever since it was replaced it's been working flawlessly. I will admit there are ups and downs with having an aftermarket remote starter but it's worth it, just my two cents
Old Mar 2, 2014 | 08:04 PM
  #65
YelloEye's Avatar
If I didn't think my car would roll off without being in gear I'd contemplate getting one. I've never personally had that issue, but know people that have so I'll pass.
Old Mar 2, 2014 | 08:37 PM
  #66
serega12's Avatar
used it this morning and at school. love it! I think every car should come with one. It's really easy to do the sequence to make sure it's in neutral.
Old Mar 2, 2014 | 08:40 PM
  #67
EmperorJJ1's Avatar
i only put my car in gear maybe 1% of the time.
Old Mar 3, 2014 | 02:49 PM
  #68
gloomy04's Avatar
I found a company that is going to do it the right way for 700 plus tax. I want the window module too
Old Mar 3, 2014 | 07:58 PM
  #69
Mine's in gear 100% of the time.
Old Mar 9, 2014 | 04:36 PM
  #70
serega12's Avatar
Mine was $780 out the door, parts and labor. Window module included. Lifetime warranty for labor at any Fry's Electronics and on parts through DEI since it was purchased and installed at an authorized dealer.
Make sure those guys are authorized dealer if you want any kind of warranty. They will need to do a two-relay with custom measured resistor setup for the clutch bypass and another setup just like that for the immobilizer bypass. All that info is available on DEI website, they should have a log in for that...
Old Mar 12, 2014 | 01:34 PM
  #71
alerosaint's Avatar
nice!! glad you got your set up up and running properly Seraga. Yeah Im loving jumping a car thats warm ready to boost lol.
Old Mar 16, 2014 | 07:12 PM
  #72
serega12's Avatar
Yep. Warm when it's cool out or cool when it's hot out. I got my windows and the sunroof wired to it to crack either one or both, or roll them all the way down from my remote. And if I arm the car and forget to close either one - the alarm will do that for me.
Old Mar 16, 2014 | 09:33 PM
  #73
now that I have a cobalt again.. subd for answers
Old Mar 16, 2014 | 09:57 PM
  #74
serega12's Avatar
Nice. You got the Cobalt and the caddy?
And what answers would you be interested in?
Old Mar 16, 2014 | 10:37 PM
  #75
nah, Caddy was leased and found someone who took it for me... thank GAWD!! but just poking around with the remote start, I WILL have it by next winter, weather I install it or not but I must have it. I'll be keeping this thread in mind when I actually get going with all this.
