Remove dome light?
Old Aug 28, 2008 | 05:51 PM
HyphyDrivah's Avatar
Remove dome light?
How do you take out the dome light assembly (not just the cover but the white piece covering the wiring)?
Old Aug 28, 2008 | 05:54 PM
mkulrey13's Avatar
why? I beleive you just pull it as its just attached on the liner by a lip of some sort. or take the inners out and find a screw?
Old Aug 28, 2008 | 06:10 PM
One of the map lights went out and its not the bulb, Im thinkin its a wire. And Ill give that a try
Ok I gave it a pull. Didnt want to come without seeming like itd break or tear up the headliner. No screws that I can see. Any other ideas?
Last edited by HyphyDrivah; Aug 28, 2008 at 09:10 PM. Reason: Automerged Doublepost
Old Aug 28, 2008 | 11:12 PM
Silv3r's Avatar
This is kinda the opposite of what you want, but the pics might show you. From what I can tell it's mounted in with bolts.
https://www.cobaltss.net/forums/how-guide-43/how-install-dome-light-vehicle-sunroof-124078/
Hope it helps.
Old Aug 29, 2008 | 12:21 AM
I dont have a sunroof so its different. They drill holes to bolt it onto the sunroof electricals. This is annoying since I already know the dealership wont cover it. Does anyone know how to get behind this assembly without tearin up the headliner?
Old Aug 29, 2008 | 12:45 AM
deuce's Avatar
you have to pop off the sideskirts on the headliner, then it will drop down i believe
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
