SCer rotors
Old Mar 8, 2007 | 07:05 PM
yellowshowbalt's Avatar
SCer rotors
how do you remove the SCer roters for porting
Old Mar 8, 2007 | 08:16 PM
syP's Avatar
syP
there are bolts around the snout.... un bolt them... pry gently around the "seam" where the snout meets the rest of the casing.. it will just pry off.
it does at least on my M90 supercharger.. i figure the m62 is the same.
Old Mar 8, 2007 | 08:43 PM
its comon sense to unbolt the snout !!!!!!!!!!!!!!!! i dident know if i could just pull on the gears and they would come out
Old Mar 8, 2007 | 08:55 PM
syP's Avatar
syP
stop shouting.
there should be 3 pieces to the blower...
snout... connectes the the middle piece which is sandwiched between the snout and case..
the middle piece has 2 gears on it on one side, and rotors on the other. The rotors ARE connected and you just slide the middle piece out.
Old Mar 8, 2007 | 09:10 PM
Blown 4-banger's Avatar
I posted a how-to like 3 days ago but THE DAMN MODS WON'T ******* POST IT!!!
Old Mar 8, 2007 | 09:41 PM
im sorry i wasent shouting. i figured it out and i cut the hole square out im taking it to work tomorow to polish it all up and make it smooth. thanks for the insight and info "blown 4-banger" by the way now its 3in wide and 4in long square hole.
Old Mar 8, 2007 | 11:18 PM
SSdan's Avatar
I don't think that is good..........
Old Mar 8, 2007 | 11:32 PM
M88ArRamadi's Avatar
Old Mar 9, 2007 | 04:44 PM
ill post a pic of what ive done its sweet looking it should realy lower the air temps at max boost
Old Mar 9, 2007 | 06:18 PM
Dude, you do know its shaped like a V to match the angle of the rotors right? Without it, your air flow with be all effed up. I don't even know if you'll make boost now! The rotors might suck air back into the housing, it might end up just swirling the air around all over the place.
Old Mar 9, 2007 | 06:23 PM
0redline6's Avatar
o man this thread will be intersting in the next few days....... bolt this 'uber ported' blower on i wanna see what happens... plz link a video.. an im not being sarcastic or anything i really wanna see lol
Old Mar 9, 2007 | 08:18 PM
i know what yall are saying. and it took it into consideration. i looked at very well and eyed it out before i did the cutting - it will still create boost - because it has all the side housing and everything. ill let u all know soon what happens. ps- i didnt have time at work today to polish it up.
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
dieGone
Sep 23, 2015 10:20 AM
